Results 1 to 7 of 7
Thread: swap done ... nearly!!
    GTRCer illmatic_1's Avatar
    Apr 2007
    abbotsford, BC
    192
    ok .. over the past few days i grunted me way into the n/a to turbo club, and in the afternoon today the car came to life idles alright but when i try to throttle it up i get power past id say 3 grand .. and when i screw around with the intake piping the car wants to die .. (im assuming theres a leak .. and thats what is causing the problem .. anyone care to confirm ??).. a friend and i worked out a few other kinks, (iene shot coil pack, ticking injector) gonna get a new intake tommarow hopefully and see if that makes a difference wish me luck
    as well i checked out other pissibilities charge piping, maf, ect .. none seemed to bewrong
    as for aftermarked parts... an fmic kit thanks to Berard_Kassis wich fit with little modification and allowed me to keep my fogs, apexi boost guage and plx wideband AFR guage , greddy turbo timer , and turbosmart supersonic bov(not installed yet waiting for adaptor plate)
    lastly a gtr hood i recieved from greyhound (A$$#&!@$), that was in mint condition when it left its destination is now nearly written off ..now are the gtr hoods east to fix .. (whats wrong: all four corners are bent , paint is chipping all over) obviously i cant paint it ,other then flat black, but is it ok to bang it back iinto shape of am i gonna do more harm then good
    anyway just wanted to do a show and tell and ask some questions http://www.cardomain.com/ride/2611803/1
    GTRCer BigBlueR32's Avatar
    Feb 2004
    Brampton, Ontario.
    1,929
    The hood is toast, an experienced body guy might be able to fix it but unlikely, Aluminum is almost impossible to straighten out.
    As for the issue, can you rev to redline fast? , slow?, under load? when is the issue?
    As well what are your coilpacks reading? Did you clean your maf or have access to another one to test?
    And lastly check all your clamps and make sure there all nice and tight, as well as check the welds on your pipes/intercooler to be sure no air is leaking out.
    The Evil 4 Door
    Nissan Skyline GTS-4 Sedan
    GTRCer Braden @ JNS Imports's Avatar
    Jul 2006
    Lethbridge AB
    5,269
    feel horrible about the hood, greyhound should pay for it, i can show them pictures of before the shipping.
    GTRCer feyd182's Avatar
    Nov 2006
    Edmonton, Alberta
    697
    Hey man, sounds like you are on the way! I had a similar problem when I did my swap and found it to be a vac line that was missed on the rebuild, after solving that problem I've put at least 1500km on it with no issues. The only thing I miss about the N/A engine is the low end torque that disappears in the turbo engine. Hope everything works out for ya, and welcome to the "club" ha ha
    89 Skyline GTR [daily]
    89 Skyline GTS-T [sold]
    GTRCer VicSkylines's Avatar
    Sep 2007
    Victoria, B.C.
    1,681
    aluminum sucks to work on man.. if you have a torch at your disposal get out your hammer. hammer into place and get a lead or tin stick(body man tool) heat up the metal with torch (BE CAREFUL aluminum is a **** and will go solid to liquid quick) to heat up and lead surface (heat metal.. take away heat then use the lead stick like a pen over bumpy bits) to build up over the bumps then u can just sand away excess. if you can do this it will save u body shop $$.
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    Also mind you Aluminum has the tendency to weaken after heating (needs annealing for structural revival). Sucks about the hood, any way to get insurance?
    edit: It also has a short fatigue life compared to steel. Too much adjustment (bending back and forth) will cause fracture.
    Sep 2007
    Victoria, B.C.
    1,681
    Quote Originally Posted by M13 View Post
    hence the quick blast of head then lead stick then heat then lead stick
