Results 1 to 6 of 6
Thread: Project GTS-R
    May 2008
    BC
    10
    Project GTS-R
    Well project GTS-R started mid may with a whole new turbo setup and is awaiting the sale of my RB20DET before the RB26 can be rebuilt. My goal is around 600hp on a 2.7L single turbo RB. My base is my 89.5' GTS-t Type M. I have had this car for over 3 years and have finally decided to empty my bank account.
    Previous mods:
    Apexi Power intake
    Nismo AFPR
    3" exhaust
    Apexi N1 muffler
    Autometer boost and fuel pressure gauge
    Mines tuned ECU
    New mods already completed:
    Top mount T70 w/boot
    Top mount stainless steel exhaust manifold
    Custom down pipe with heat wrap
    FMIC
    3" intake piping
    Aluminum radiator
    Walbro 255lph fuel pump
    Innovate Motorsports wideband O2 w/XD-16 gauge
    Greddy E-manage Ultimate w/AF harness
    Q45 MAF
    Nismo low temp thermostat
    Nissan N1 water pump/tensioner/idler/timeing belt
    TiAL 38mm wastegate
    TiAL 50mm BOV
    Turbosmart boost controller
    Dual 12" electric fans w/thermostatic switch
    Greddy oil catch tank
    Next edition:
    Swap out 20 and rebuild the 26
    700cc SARD injectors
    N1 oil pump and crank collar
    N1 water pump/tensioner/idler/timing belt
    ARP bolts
    ACL bearings
    Greddy head gasket
    Wiseco Pistons
    Eagle rods
    JUN manifold gasket kit
    JUN stage 2R cam kit (valve springs and retainers)
    Greddy oil relocation kit
    Stock crank
    300xz tranny with rb26 bell housing
    Exedy stage 2 clutch
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    I would add a N1 shortblock to that list.
    May 2008
    BC
    10
    If I am going for about 600hp range would the stock block not be sufficient? What are the benefits of the N1 block? What would be your advice on the crank then? Stock should be fine right?
    May 2008
    BC
    10
    Have looked into N1 block and will most likely do. Curious though if all additional components are the same as for the stock R32 block ie intake manifold, water pump, oil pump etc? Thanks.
    Apr 2008
    Coquitlam (Vancouver) BC
    4
    needs pics :-o
    May 2008
    BC
    10
    Quote Originally Posted by Scotty-R View Post
    needs pics :-o
    I am not entitled to add attachments yet, so pics will come when I am allowed.
