Page 1 of 8 123 ... LastLast
Results 1 to 10 of 80
Thread: Gt30 rb20 build - 1 Year Project + Paint Job Pictures
    PL_GTR's Avatar
    Oct 2008
    Vancouver
    969
    In progress build, looking for 400hp at the engine summer 2010, working on supporting mods for now and other adds.
    My 92 gts-t
    Current mods
    -Trust Intercooler (beat up)
    -yellow jacket performance coil-packs
    -ngk spark plugs
    -new AEM rotors front and new brembo rears
    -hawk hp+ break pad
    -new vacuum lines
    -manual boost controller
    -apexi boost gauge
    -hks turbo timer
    -new downpipe
    -new testpipe
    -exotic speed catback exhaust
    -pop charger air filter
    -new speedo cable
    -eneki rp02 rims 17 X 8 +38offset all around refinished 225/45/zr17 front and 245/40/zr17 rear
    -Refinishing was done at Panther Recommended for sure
    -full paint job, including door jams, new clear on signals and tail lights
    -gts-t type m spoiler painted
    -r32 gtr N1 Oem bumper with air ducts + Painted Lip
    -nismo rear control arms
    -JIC coilovers
    -walbaro fuel pump
    -synapse blow off valve
    -type M side skirts and rear valance
    currently running 0.9bar on stock rb20 turbo on 94 octane
    Winter 2009
    -Waiting for gauges from Adam. Apexi - Oil Pressure, Oil Temperature, Water Temperature, Boost + Control link module
    -stainless steel breaklines
    -sparco deep corn steering wheel
    -worksbell steering wheel hub
    -megan racing quick release
    -AEM wideband air and fuel gauge
    -Greddy a-pillar pod for gauges
    -2 way alarm
    2010 skyline build
    -Gt30 Garrett or HKS turbo, looking for 330 rwhp. (Goal for full spool is 4000rpm)
    -electronic boost controller
    -Trust type r intercooler or some other hybrid one
    -q45 maf
    -gtr 444 injecters
    - SARD fuel pressure regulator
    -injector resistor pack
    -top mount manifold
    -tial wastegate
    -screamer pipe
    -nistune or mine's ecu
    -new nismo front tension rod
    -tomei headgasket
    -APR head bots
    -custom downpipe
    -A/N fitting all around hopefully
    -Catch Can
    -Clean Engine Bay
    If money left over
    -tomei pon cams
    -hks adjustable cam gears
    __________________________________________________ __
    This is the whole paint job i got from a respected private guy.
    KL0 - Z-tune silver with a lot of pearl
    primer, 2 coats, 3 clear
    ***Before*** Sparkling silver
    ***During***
    ****After****
    Will try to update as i go along with my build
    Info for paint connection not available at this time as he is really busy, but when he becomes available it will be first come first serve basis. I will let you know here if any updates. All directly related paint questions and prices do not go through me.
    I want comments and suggestions to help my build out, i know there are a lot of smart guys and girls out there.
    Cheers
    2014 - Screw this build, R34 time lol (Full mine's prepped motor 600awhp)
    R33 Skyline GTR VSPEC (White)
    RABBIT's Avatar
    Oct 2007
    Toronto
    3,167
    literally one of the purrdest H chassis on here . im so happy ur builing up the 20 .
    such a great motor im aiming for 550 to the crank my self .
    i dont see any plans for your cooling or oil system should be upgraded for sure.
    RB20DET[FTMFW]FOOLS//.
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    I like.
    A few questions about Synapse BOV, if you don't mind.
    Did the stock rubber recirc intake hose joiner fit over 1.25 inch BOV recirc fitting that was shipped with BOV????
    How do you like the Synapse BOV????
    The reason I ask as I need to replace the stock BOV that's causing flutterdump / compressor surge problems.
    Also fit Nistune. Nistune can run the same maps your car is running now and be reprogramed for future mods. Mines ECU can't, as Mines put glue over EPROM chip.
    GTRCer Snow's Avatar
    Feb 2009
    KW Area, ON
    1,745
    OMG I agree with Rabbit for once.
    Kodak moment *smiles* *Click*
    But seriously, I think you may want to consider a new rad and oil cooler/filter relocation. Why not when you're in there?
    I would also suggest a stronger clutch. I can't remember if you're running your stock one (from above notes I would assume yes) and that'll be smoked pretty quick with 400 at the crank (or so I would assume).
    I would keep an "oh **** I broke it" fund for your rear end and tranny too.
    And I would suggest before getting knee deep in this **** you fully anticipate doubling your budget. Just look at Mikes car. F-cking SICK. But f-cking expensive too.
    I'm excited for you. I'd love similar power at lower spool. I have alternative ideas tho...
    EDIT: I thought it said RB30 build, not GT30, and I was going to walk up and smack you at the next meet since I know it would never happen
    PL_GTR's Avatar
    Oct 2008
    Vancouver
    969
    The synapse is a long story, i don't know if i got unlucky or whatever, but this is the 3rd one for me, I am lucky i bought it at ztune and it was covered under warranty, but for future buying of bovs, i am going to stick with hks, greddy, or blitz.
    The diaphragm on the bov broke on me twice at 14 pounds of boost.
    The recirc one that i have now is fine, working for now. Mike on here helped me fabricate a silicone heater hose that went from bov to recirc pipe.
    thanks rabbit, i forgot to do the cooling stuff, but i will probably get electric fans and an aftermarket rad. oil cooler maybe, but its going to be mostly for street.
    PL_GTR's Avatar
    Oct 2008
    Vancouver
    969
    i have a practically brand new nismo twin plate and its fine for my application.
    snow i will be able to get the Mine's Gtr if i get into a career sooner or later, its still a few years off and i am both working hard and being optimistic. I gave up on the whole lottery thing lol.
    Sep 2007
    South
    6,702
    I see, thanks.
    From what I can see from construction diagrams, Synapse BOV doesn't use a diaphram, it uses O rings. Sometimes if O rings aren't lubed when installed, they can break or be damaged and not seal properly.
    I thought Synapse BOV needed a different recirc joiner, as I measured stock BOV recirc fitting at 29mm / 25.4mm = 1.1417 inch or so. So stock rubber recirc joiner won't fit over a 1.25 inch x 25.4 = 31.75mm fitting. Would have to buy their recirc joiner. Just as well, as I need to replace that joiner due to stock intake hose clamps producing cracks in that joiner.
    Here's the 1.25" silicon hose joiner on their website -
    http://synapseengineering.com/cart/p...pler-85-5.html
    Do you have rough idea on length of that joiner, as 76mm might not be long enough???
    What did you do for boost feed???
    Feb 2009
    KW Area, ON
    1,745
    I never doubted the mines GTR.
    Where there's a will there's a way.
    But on that note, it will come sooner if you save your money now
    PL_GTR's Avatar
    Oct 2008
    Vancouver
    969
    i take some pictures for you, but i am not expert on Bovs. mine came with like a wide adapter thing on the bov end where we attacked a rubber hose from napa + silicone rad hose and made a join from bov to the re-circ pipe. It idles at 850rmp when engine is warm.
    Edit. ya you don't need a specific cuppler from synapse, just make your own, it works fine.
    ya 7 cm is way to short, now way it will make it
    Sep 2007
    South
    6,702
    Would be much appreciated, thanks.
    Were all learning something new everyday about our cars, nobody knows everything, including me.
    Where I am, don't have access to a NAPA store.
    1inch = 25.4mm. At least that's what it says on conversion chart I have.
    76mm / 25.4mm = 2.9921 inch or roughly 3 inchs, which like you have already said, doesn't look long enough.
