well, here it goes guys, started off with a 90 s13 fastback shell, and fixed a spot on the frame,the shock towers, and a hole in the floor.
engine bay shots while stripping it down and stitch welding the chassis
Chassis
tremcladed it so it wouldnt rust
installed tein tension rods
also has megan street coils installed, havent taken pics since im sure you know what they look like,
then picked this up to kick off my build
http://www.projectzig.com/v240...240.0
Engine/drivetrain
rb20 shots
and in the car ftw
Apexi 3 inch catback, going to get a 3 inch dp/cat delete made
installed vlsd and axles from the r32
Brakes
for brakes i used the r32 brakes all around, redrilled for 4 lug, cause i have so many 4 lug drift wheels, but ill be going 5 lug eventually. used the r32 knuckles, e brake assembly, all e brake cables except the front ones, r32 rotors and calipers.
e brake assembly and 4 lug hub installed
rotors redrilled
all installed
and with the dirty wheel on
installed my egt probe today, wired up my tach and temp guages, and maybe a little test drive?
engine shot
had to tee the brakeline for the front since it only had one front output, the other didnt have the seat for the flare
i think im gonna need a pusher
front shot
missing something?
side shot
ok today installed auto meter mechanical boost and oil pressure gauges,autometer egt and my innovate
lc1 wideband, heres some vids and pics
http://s25.photobucket.com/alb...0.flv
http://s25.photobucket.com/alb...5.flv
done alot since i posted last, blew the last motor and swapped in another one. had the old one dynoed at 256whp at 15psi, new one has less k and a rb25 turbo. so with my new injectors and more boost im shooting for around the 3 mark.
painted car shadow grey metallic
front 20mm fenders
cage installed
removed all carpet and bedlinered inside
stripped rear harness of un needed wiring and tucked it in the frame
sparco sprints and rci harnesses
rota p45rs. specs on wheels are 18x9.5 +20s with an 8mm spacer (wheels took like 3 months to get here and +12s where custom and wouldve been another 3 months)
pics!
heres my other wheels with azenis in front for sliding and s***ty drift tires in rear
LinkBack URL
About LinkBacks
lol. much respect. post up some videos of you sliding perhaps
