After owning my car for close to two years, with just doing the normal bolt on’s. I figure it’s about time to start a project thread although it will be progressing fairly slowly though. My goal is for around 400 reliable WHP on my RB20.
So far I got:
Tomei MLS head gasket (stock thickness)
Tomei strengthen timing belt
New tensioner pulley and idler bearing.
New OEM water pump
Nismo clutch pivot
Holset H1C turbo, stock manifold with external w/g flange welded on, 38mm External waste gate (no name). I’ll try it out but probably change it.
Trust FMIC (may have to change to bigger piping and core).
HKS EVC boost controller.
What’s still on my need to buy when I have money list:
GTR cams
Adjustable cam gears.
Deatschwerks 550cc injectors (or GTR 440cc, still unsure)
Adjustable FPR
Nistune
Tomei GTR 276lph fuel pump
ARP head studs.
Still unsure of clutch, im thinking ACT (suggestions?).
Koyo radiator
2 12” electric fans
N1 oil pump.
Innovate wideband.
Digital Auto meter cobalt oil pressure and fuel pressure gauges.
Auto meter cobalt boost and water temp.
Possibly an EGT gauge (useful?)
That’s about it, im sure I probably forgot a few things in there somewhere. Suggestions and criticism is appreciated. Pictures to follow once I actually make some progress. i hope to have it tuned and finished in two months. i plan on running pump gas to hit my horsepower target, im pretty sure that is possible on stock pistons and rods?
LinkBack URL
About LinkBacks
