Results 1 to 4 of 4
Thread: needed help(timing gear removal)!!
    GTRCer supersayianjim's Avatar
    Apr 2010
    saint joseph m.o.(u.s.a.)
    162
    hi guys. doing an overhaul on my rb20. and ive ran into the same problem i had the first time i got to the timing belt. seems the lower timing gear is seized on and refuses to move. worst part is there is no cleareance to get a gear puller behind it and pull it off. the best i can do is a flat head screwdriver..
    http://i495.photobucket.com/albums/r...ingproblem.jpg
    http://i495.photobucket.com/albums/r...b/SL732115.jpg
    http://i495.photobucket.com/albums/r...hclearance.jpg
    any takers on the soulution that will set my gear free??
    __________________
    GTRCer m_melen's Avatar
    Nov 2008
    The Great State of Texas
    1,779
    you're boned. it just happens a lot to these engines.
    i had my engine out when i did mine, and i ended up having to drill off the oil pump, take the crank with bits of the oil pump and that timing gear still attached to a local shop where they hit it with the torch and an air hammer w/a chisel and it was still tricky for them.
    GTRCer sarazinj's Avatar
    Jun 2009
    saskatchewan martensville
    204
    take the block to a local engine rebuilders, you would be surprised what tricks they have
    Owning a turboed car is a great way to prevent your jackstands from getting stolen
    Nov 2008
    1,779
    boned. haha sorry, it just really sucks to get off
