Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Looks like stock but..
    Oct 2010
    Seattle, WA
    2
    Currently got a 1990 Nissan Skyline GTS-t Type M with an RB20DET(stock) engine.
    Going to be swapping the RB20DET for a R34 RB26DETT and adding quite a bit to it.
    New turbo, intercooler, intake, exhaust, ems, differentials, clutch drivetrain, brakes, fuel pump, wiring system, complete rebuild of the engine, along with the sightly additions of a body kit (wide fenders, new front/rear bumpers, hood, and wing), fix the interior, new sound system, new paint, new tires, new rims, yadda yadda yadda.
    I'm looking in the area of $15k - $20k on performance alone
    Gonna try to get in the area of 600whp.
    Thoughts, suggestions, comments, concerns, ect.
    Currently:
    Looking for:
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    for 600awhp, you'll be spending 12k$+ on the engine alone, without the cost of the actual engine, which for a R34GTR's is 5k$+
    then, clutch and diffs will be at least 4k$
    2k$ for wheels&tires
    at least 5k$ for body mods and paint
    brakes and suspension is 2k$+
    know how to swap the awd RB26 into a rwd chassis?
    got any experience with the R32 chassis?
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Like RB20, RB26 doesn't have much down low. But similar feeling to NA bigblock V8 at peak hp.
    Could stroke a G35 engine to 3.8-4.0 litre (R35GTR crank, R35GTR aftermarket pistons, R35GTR aftermarket H beam conrods, etc) and fit a local made (USA) aftermarket twin turbo kit (AMS manifolds, turbo's, etc) for a R35GTR. That way you retain bottomend hp, but can extract up to around 800whp at something like 22.5psi. Then run low boost, 600whp as everday setting (probably would need to, so can gain traction).
    Or use a Titan V8 as it supposedly has iron sleeves as stock equipment (Nissan Titan trucks in USA) and twin turbo it or fit a supercharger kit, like on this G35 -
    http://www.youtube.com/watch?v=gOtYO2XwmrA
    GTRCer doublejceballos's Avatar
    Sep 2008
    Abbotsford, British Columbia
    2,048
    Quote Originally Posted by Greg View Post
    Currently:
    Looking for:
    That blue GTR has the famous veilside E3 widebody. you wont be finding those fenders for your car
    of course however there is another route:
    Case Closed:
    FS Veilside 92 Widebody GTR 25000k Abbotsford BC
    email me for updated pics, info and price
    d ou bl ej ce ba ll os@ ho tm ai l.com
    Quote Originally Posted by Oakville View Post
    GTRCer nelsonmxmarc's Avatar
    Jul 2009
    Montreal
    2,039
    yea respectively, if you're looking to make 600whp in the most cost effective way possible, v8 is probably your best bet.. Can always find a wrecked LS.. 1 - 7 and grab some pretty bad-ass tq at the same time. 26 swap is a great idea, but ive toyed with the idea enough that putting one in a GTST will never yield less than 8k, and that doesnt include much engine work (light headwork, valvetrain, turbo) because we tend to spend more time on the drivetrain itself.. Fit a 25 trans, fit a 25 yoke.. Then the issue of the LSD holding up.. It's not as strong as that of a GTR, and unfortunately a GTR diff wont bolt into a GTS subframe. Costs of a NEW LSD to match will run you up in the 2000$ mark.. So then your best option would be to source a GTR subframe, as well as all matching suspension components and have it fit in place (1000$ give or take) - at this point you're still stock and have spent a great deal of money on crap just to GET to the point of actually beginning to build something.
    With that money, you can invest in a good strong powered V8, driveline and an uprated LSD (1500-2000$) ball parking 6-7 g's.. Crate motors are relatively cheap from the US.. Or if you want to be a Nissan supporter, like Skym mentioned, Titan V8, or even a go with an 6 like Charles is doing and run NA. Still attain some pretty decent power..
    It's all up in the air. A 26 swap and proper build would be epic, but a 26 swap with body/chassis and motor work to achieve 600 whp is going to be rather pricey.. Probably up in the 20,000$ mark after everything's said and done.. It adds up quick..
    www.nelsonmx.wordpress.com
    Jul 2009
    Montreal
    2,039
    Gorgeous car man!
    cschepp's Avatar
    Jan 2008
    _________________
    4,323
    It would be awesome to see but for the veilside kit on the car and engine to match your description will be kinda pricey. You can also go rb30 and have one built and modified for that cash. I know everyones not really keen on the rb30's I personally love them. Also you can turbo a 350z engine or a g35 engine and you'll be rocking. Just make sure you think long and hard about it because once you got some serious money into it there's no turning back
    Apr 2004
    Edmonton, Ab
    545
    It would be cheaper to sell the gts-t and buy a gtr and convert it to rwd if you wanna go that route. If you want a reliable 600whp its going to cost more than 20k, even if you do all your own work.
    Don't bother with the engine swaps. They are going to be nothing but headaches and will take 3x longer to finish the car
    GTRCer RWD_GTR's Avatar
    Jun 2008
    lethbridge
    827
    looks like stock and is stock?
    i would call it an impossible task if your going to awd it. wayyy too many mods needed.
    also rb26 is a stupid idea if you want 600whp right away. like they said ls1
    if you want an rb26 get a gtr. if you want rwd for this dont get an rb26.
    RB25 Powered RWD GT-R
    Sep 2007
    South
    6,702
    I agree about using GTR chassis and converting to rwd. Also you'll probably won't get traction up until 3rd gear with rwd RB26. I know this from someone who had a rwd RB26 racecar (GTS chassis) and had traction problems.
    What I have been told before. "Don't try to make it something it's not".
    R32 GTS-T is a good Targa car, which is sort of what the factory designed it to be and what it's good at.
    R32 with boosted up stock RB20DET is very good at being a Targa car, as shown when it passes a boosted up stock R32 GTR -
    http://www.youtube.com/watch?v=fgD5j52ltFA
    It's faster than a lightly modified stock R35GTR on same stage. But on par with a EVO with stage times in Targa.
    R32 GTS-T (4.21 -0.11 = 4.10 stage time) -
    http://www.youtube.com/watch?v=CI7EWrDCjcU
    R35 GTR (4.24 -0.10 = 4.14 stage time) -
    http://www.youtube.com/watch?v=uxu5rj8ZACI
  1. Replies: 0
    Last Post: 08-11-2010, 06:04 PM
  2. FS: stock ecu, stock MAF & PS Pump BNR32
    By HTR-Maniac in forum Parts for Sale
    Last Post: 06-04-2008, 04:52 PM
  3. fs:stock gtr hood,stock gtr rad,new r34 water pump
    By colin in forum Parts for Sale
    Last Post: 05-28-2007, 01:33 PM
  4. R32 GTR Stock Boost on Stock Boost Gauge
    By xcye in forum GT-R Tech
    Last Post: 11-18-2006, 03:09 AM
