I've had so many ideas of how i want to build my Gts-t but seeing how i moved out last year and having to spend my money on rent and everything else I've narrowed my swap and build down to this
My current set up
HKS evc6
HKS intake
FMIC
control arms for front and rear tires
tension rods for front tires
BF goodrich 245 g-force kdw in the back
all aem gauges, oil temp, oil pressure, water temp, boost, a/f ratio
mishimoto oil catch can
mishimoto oil cooler
mishimoto dual fan shroud
mishimoto rad
greddy oil relocation kit
spitfire coil packs
gtr-hood
tein HA coil overs
mines ECU
3inch down pipe and 3 inch free flowing exhaust (deleted
cat)
can't remember but good spark plugs heat range at 7
never filled up on anything below 94 octaine
Denzo fuel pump
all AMS fluids including oil, rear diff, tranny
optimal yellow top battery
z32 maf
large tach with a shifter light
stock turbo set at 12 psi
turbo timer
-I think that is pretty much everything worth mentioning
My plans for a RB25det swap
greddy plenum
550 cc injectors
garret gt30
planning on patching in a Haltach ecu
keeping rb20 transmission
cams
arp hardware
powerbond harmonic balancer
Q45 throttle body
repaint engine bay black
metal head gasket
gasket kit
dual fuel pump
LinkBack URL
About LinkBacks
