Results 1 to 5 of 5
Thread: gtst
    May 2010
    winnipeg manitoba
    4
    gtst
    so iv fooled around with my stock recirculating valve and i thought with the hose off that it would have a louder pshhhhhh effect... so i took it off and the sound was just how i wanted it but it would stall at idle....if i was to install a blitz style bov (non recirculating) would it work??????? this isnt a really important project but i just thought why not have a sick sounding bov right???? can anyone help me out
    GTRCer Nismo_line's Avatar
    Nov 2009
    204
    1,501
    wrong section
    rak123's Avatar
    Dec 2008
    Winnipeg
    494
    No matter what atmospheric bov you have the engine will run rich immediately off throttle. If I were you I would keep the stock recirculated until u get an aftermarket bov because the stock ones are known to leak and you can loose air once you start to boost.
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    hahah
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    you stock valve now works like a atmo BOV, since it releases to atmo, you don't recirculate the air anymore, sure the engine will stall,
    even if you install an aftermarket BOV, i'd suggest getting a tune to avoid stalling problems
  1. 500 hp gtst
    By all-Canadian11 in forum GTS Discussion
    Last Post: 12-01-2010, 02:22 AM
  2. Z32 MAF on GTST
    By SalEsh in forum GTS Tech
    Last Post: 04-09-2009, 10:19 PM
  3. GTR Or GTST?
    By steeldawg_69 in forum GT-R Tech
    Last Post: 07-29-2008, 05:33 PM
  4. LSD on a GTST?
    By Boyscout in forum GTS Tech
    Last Post: 02-03-2007, 02:52 AM
  5. gtst
    By felixy69 in forum GTS Tech
    Last Post: 09-20-2004, 11:09 AM
