I love the Nissan Skyline, I also love chevy 350's so I thought why not put 2 and 2 together and get a BEAST. Now I know its not going to be just a drop in project but over the last couple weeks Ive been looking at empty R32 GTS-T engine bays and i think it wouldnt be the hardest thing in the world to do. The first major problem to deal with is engine clearance (mainly the oil pan being able to clear the cross member) Now what i was think is instead of using the normal rear sump system that most chevy 350's use a 62-67 chevy2/ nova front sump siystem which will put the sump exactly where a RB2.0's is. The next problems i would run into would be mounts engine and trans. If anyone else has tryed to put a 350 in a R32 please reply with any problems/tips. Another thing that would be very helpful would be the spec for the lsd viscous rear ends (would they be able to hold the power?)
LinkBack URL
About LinkBacks
For the trans. bellhousing and #4 shifter to fit even better wouldnt I be able to cut away and weld a custom sheet metal trans. well. #2 wouldnt a custom dash cluster with a painless wiring harness work? #5 Hahaha should be good for drifting right? well thank you once again i hope to here more input!! Also ill put up a few pics of the engine so far!
