Page 1 of 10 123 ... LastLast
Results 1 to 10 of 98
Thread: Project: Ultimate Response GTS-T
    klys's Avatar
    Aug 2004
    Lachenaie Qc
    4,417
    Well over the course of the winter I will try to see if my project is feasable. I will gather as much info as I can as I don't think it has been done before in Canada.
    I currently have an HKS GT2535 and Although I like it very much (very very much :P ) I beleive the RB20 powerplant could be a bit faster to spool.
    Also I'm basically limited to under 400HP at the crank with this turbo.
    I could go for a bigger one BUT. One thing I wouldn't want is added lag!!
    I'm really starting to like my Idea:
    Going for a Twin turbo setup on my 2.2L platform !
    I'm looking for either twin GT2510's OR twin HKS GT-SS's.
    my current Hurdles are: the twin turbo Exhaust manifold for the RB20 head And the Electronics associated.
    I could certainly attach a dummy intake with a single Z32 MAF (My current) but I feel this is probably not as accurate as a twin MAF setup or all out MAP.
    I'm also somewhat worried about the RB20 head that doesn't flow enough air and that it might cause a bottle neck above 400hp
    My funds are limited and I will porbably need to buy a new clutch next year as well as another Diff.
    I will have more details as the project comes along
    here's a teezer:
    http://klys.kicks-ass.org/skylines/_...IDES/GT-SS.htm
    Marc-André
    _________
    2.2L RB20 GTS-T
    GTRCer Cory Scheuer's Avatar
    Mar 2006
    SK
    570
    sounds like a good project.... i hope you will be redoing the bottom end and head?... and with forges internals? what manifold are you going to be using... i would get one from JUN made for the RB20 but looks like the GTR one...
    anyways hope it works out... looks like a good project
    Cory
    MNW
    MNW is offline
    MNW's Avatar
    Apr 2004
    Regina, Sk
    2,194
    Quote Originally Posted by Cory Scheuer
    Cory
    unbeknown'st to you obviously, klys' engine is already built (rb22), so he already has a good start on most other people
    klys, as for more HP, more HP means more lag
    lucky_cefiro's Avatar
    May 2005
    Toronto
    1,798
    hey Klys, i was looking around at this myself, from what i've seen on a standard rb20 with stock gtr turbo's 9psi came on at 5000rpm...nto much of a powerband...that could also be because of the piping they used.
    if you need somone to fab the manifold, let me know, i've had it figured out for a long long time how to do it...and on the cheap.
    klys's Avatar
    Aug 2004
    Lachenaie Qc
    4,417
    For sure Mat I will need so help with the manifold!
    I don't get how two small ceramic turbos like that took so much time to spool
    However I'm sure that 9 PSI from both the GTR turbo probably flow more air then my 15PSI. the difference being that my 15 PSI come on at 3500rpm :P
    I'm still thinking .. 2530 for 2.6L 2510 for 2.2L good compromise
    anyways I really don't know yet if this is ever going to happen but I'd love to see it in action
    Marc-André
    _________
    2.2L RB20 GTS-T
    klys's Avatar
    Aug 2004
    Lachenaie Qc
    4,417
    Here are a few Goodies I have received!
    New HKS filters, they say they need to be changed every 5000km?!
    I had been runing my old one for the last 30k
    APP Stainless Steel Brake lines
    I'll see how they hold at the track!
    Nismo SS clutch line
    Well since I have an ORC 709D clutch coming in
    this might come in handy
    A Nismo harned clutch fork pivot
    Last but not least
    An OMP WRC leather steering wheel
    I also bought some Motul DOT 5.1 brake fluid
    to replace my less that a year old DOT4
    Marc-André
    _________
    2.2L RB20 GTS-T
    klys's Avatar
    Aug 2004
    Lachenaie Qc
    4,417
    Well my APP Steel Braided Lines are in!
    It kinda makes a difference but I'll See tomorrow on the track!
    I tried it a couple of times and I got to the braking threshold two three times easily.
    The feel is just a bit stiffer but not overly so
    Marc-André
    _________
    2.2L RB20 GTS-T
    MNW
    MNW is offline
    MNW's Avatar
    Apr 2004
    Regina, Sk
    2,194
    Quote Originally Posted by klys View Post
    braking shouldn't feel any different during normal driving, but you won't experience brake fade during hard driving with those lines
    klys's Avatar
    Aug 2004
    Lachenaie Qc
    4,417
    I had a great weekend at the TRAC Racing Academy
    I must also say that I didn't experience brake fade. Everyone of my friends had some but my pedal was very consistent! and I could repeat threshold braking as I pleased after a bit of practice!
    great stuff!
    on the down side my already finished tires are now down to the nylon lining
    BUT
    I got me some of these!
    BF KDW2'S
    can wait to try them on the track
    next up I will try to get me some R compound tires
    Marc-André
    _________
    2.2L RB20 GTS-T
    klys's Avatar
    Aug 2004
    Lachenaie Qc
    4,417
    Well it seems that the car still has surprises up it's sleeve!
    look at what I found today under the cover
    Woohooo!
    I decided to check on the timing belt because it made a weird sound ..
    can anyone tell me if this is a normal sound? or if the belt seems a bit loose??
    it stops doing the sound when the timing belt changes it harmonic oscillation or something
    thanks
    http://youtube.com/watch?v=Ky9Kw-0XwAs
    Marc-André
    _________
    2.2L RB20 GTS-T
