Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 95
Thread: Fix your hesitation
  1. #21
    Mar 2006
    43
    help me
    Hey guys im kinda having the same sorta problems as you guys are having
    My engine ran perfectly last year and this summer its being a lil B*tch
    The problem comes off and on, mostly when the engine is warmed up.
    The car idles to about 500 Rpm. and sounds like a Harley Davidson (like a double thumping sound out of the exhaust). But even when i rev to 1000 it still sounds the same
    Its really slow to accelerate but once i get going and i go to about 6000 RPM in 3rd gear the problem goes away with a huge clean boost kick, but comes right back in once i slow down.
    I thought it was the MAF, i cleaned it and the problem came back a day later.
    I put 94 octane instead of 91 and reseted the ecu and the problem came back a day later.
    I dont know if i am running too rich or if not enough air is coming into the engine. All i know is i feel like im driving a mustang and i hate it.
    I will keep you guys posted with updates as i go down the list provided at the top of this thread.
    But if you guys can help dont be shy please
    Thanks
    Sky_bro 1 of 2
    \"Sky is the limit\"
    -Sky_Montana
  2. #22
    GTRCer rockcrete's Avatar
    Mar 2005
    Maple Ridge, BC
    1,297
    You have a dead cylinder. Unplug the coilpacks one by one at idle until you find one that doesn't change the idle. Then you know where your problem is, it could be the injector or the ignition causing it though.
    1989 Gumetal GT-R - Nismo Turbo etc
    ivoac.ca Join the fight for the right! If you're not part of the solution, you're part of the problem......
  3. #23
    Banned
    Oct 2006
    GTRC
    2,669
    If you have disconnected your ecu lately then go back with a socket and give it a 1/4 turn of a tighten. It should smooth it right out.
    If you have not played with your ecu lately then do what rock says.
  4. #24
    Mar 2006
    43
    Quote Originally Posted by rockcrete View Post
    Ya cause the problem comes on only after the engine is warmed up, onced warmed up i do crazy backfires and lose alot of gas.
    Sky_bro 1 of 2
    -Sky_Montana
  5. #25
    Mar 2006
    43
    FOund the problem
    Its was coil #6 tested at 0.
    more expensive than a spark plug but atleast i found the problem
    thanks
    Sky_bro 1 of 2
    -Sky_Montana
  6. #26
    judasentinel's Avatar
    Jun 2006
    Toronto
    1,727
    Quote Originally Posted by Sky_Davision View Post
    thanks
    ......and cheaper than having a dead cylinder with NO compression.........:-D
    (OO)______(OO)
    FESTIVUS, for the rest of us!!
    SERENITY NOW!!!!!!
  7. #27
    Mar 2006
    43
    Compatible
    Does anyone know whats compatible with the coils.
    I think Inifinite has a an engine that has compatible coils..??
    Sky_bro 1 of 2
    -Sky_Montana
  8. #28
    GTRCer bignate's Avatar
    Jan 2007
    Fergus, Ontario
    2,296
    As far as I know they are skyline specific. Most people seem to go to splitfires when their coils fail.
  9. #29
    Banned
    Oct 2006
    GTRC
    2,669
    no, I seem to recall reading that an infiniti has the same front 3 coils (v6 turned sideways) as the skyline. But the price for one coil from nissan will be the same as all 6 splitfires. Now is a good time to upgrade
  10. #30
    Mar 2005
    Maple Ridge, BC
    1,297
    Q45 V8 coils are the same, they're around $100 a piece locally, or you can try ebay.
