Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Like Tree1Likes
Thread: Engine fluid quantities?
    GTRCer qualthar's Avatar
    Nov 2004
    Edmonton AB
    1,080
    Hope I'm not reposting anything here, but I searched here and SAU. I'm looking for all the amounts of fluids that the car needs.
    So far this is what I'm planning on buying
    Brake fluid - Motul RBF600
    Trans fluid - Redline Heavy Shockproof
    Front diff - Castrol SAF-XA (weight?)
    Rear diff - Castrol SAF-XA (weight?)
    Gearbox oil - Redline MT90
    Transfer case - Nissan Matic D
    P/S fluid - Nissan P/S fluid (dunno about part #)
    If anyone has any info for how many liters of each I'll be needing, that would be great, as well as any other suggestions.
    Thanks guys
    GTRC Comic Relief Marke's Avatar
    Feb 2005
    1,893
    The trany takes 4.1 litres of GL-4 75W90. I used Royal Purple.
    The front diff. takes 1 litre 0f GL-5 85W90. I couldn't find synthetic 85W90, so I put in Redline 75W90.
    The rear diff. takes 1.5 litres of GL-5 LSD 80W90. I put in LSD 75W90 from Redline.
    The transfer case holds 1.8 litres of Nissan automatic.
    Not sure about the others you mentioned.
    spikeone's Avatar
    Jan 2004
    Quebec
    2,308
    very good information as I will have all fluids changed once car arrives
    anyone did the whole change and can add to the list already posted on how many litres it takes of each and maybe cost?
    VVVVVVVVVVVVVVVVVVVViper!
    Murphy's Avatar
    Jan 2004
    The Wired
    1,742
    stickying . . .
    marginally literate keyboard warrior
    Feb 2004
    Paris, Ontario
    418
    Anyone heard of Amsoil?
    I know a guy who is a dealer for them, its all synthetic, just wondering if anyone has had any real world experience with it, I know they use it in racing.
    GTRCer Ezzie's Avatar
    May 2004
    Hillsburgh/Erin, Ontario
    535
    I use Swepco 201 for the LSD and tranny. This is used by a lot of the Porshe guys for racing applications.
    1991 Case 580K 2WD Extendahoe (aka "Brutus")
    2006 Ford F350 SD PSD Crew DRW (aka "Monster")
    2006 Kubota F2880 60" Mower & 51" Snowblower (aka "Buzz")
    Jan 2004
    Okinawa, Japan
    335
    Quote Originally Posted by 98ss
    I have used it with good results.
    BNR32 Owner
    Okinawa, Japan
    Nov 2004
    Edmonton AB
    1,080
    I did some reading on SAU today.
    The transfer case should take Dexron III auto tranny fluid.
    The rear diff has to have the LSD additive gear oil, while the front diff takes just regular gear oil, but will have no problems with the LSD gear oil.
    klys's Avatar
    Aug 2004
    Lachenaie Qc
    4,417
    If I have a mecanical LSD (instead of Viscous) Can I use the same gear oil?
    Marc-André
    _________
    2.2L RB20 GTS-T
    Nov 2004
    Edmonton AB
    1,080
    I have no clue, try searching on SAU :?
