Results 1 to 6 of 6
Thread: 240sx subframe swap
    GTRCer diehard_skyline's Avatar
    Nov 2007
    Québec
    88
    240sx subframe swap
    Hi
    I read somewhere that you can put a 240sx non-hicas rear subframe strait on a r32 gtst skyline
    Is it true
    and if yes how hard is it ,what I need , Do I keep the same lower and upper control arm
    Your help would be really appraciated
    thank you
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,785
    it fits directly. However you need to get rid of your HICAS lines, and even better get a non-HICAS steering pump.
    Difficulty wise, it's as much as lifting the rear of your car off, then disassembling suspension parts. Read the service manual for PROPER TORQUE SPECS!
    Nov 2007
    Québec
    88
    do I need to change all the suspensions arms or ill keep the same
    Nov 2007
    Québec
    88
    no one know please I need help
    GTRCer Skym's Avatar
    Sep 2007
    South
    7,968
    As far as I know you can fit GTR subframe with arms, etc to GTS-T, 240sx, etc, so the rear subframes are interchangeable.
    The bottom of rear shocks, diffhead to driveshaft bolt pattern, diffhead cover to subframe mount holes are usually the only differences you have to worry about. For example GTR shocks are U on bottom of rear shocks and GTS-T has O on bottom of rear shocks.
    If you have to use R32 GTS-T diffhead and bolt patterns are different on subframe, can take the backing plate (cover) off back of 240sx diffhead and attach to GTS-T diffhead (might need new gasket from Nissan).
    If you want non HICAS, use a non HICAS GTS subframe and non HICAS GTS powersteering pump or I think R33 powersteering pump is another option.
    Hope that helps.
    Nov 2007
    Québec
    88
    thank you
