Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Rb 20 upgrades
    GTRCer Zimm's Avatar
    Apr 2010
    Regina, Sask
    146
    Rb 20 upgrades
    Hey i need help on figuring out what to do... |Im loooking and purchasing gtr injectors and fuel pump.... alsomy car now runs rich and i want to get like a power fc or safc,,, any ideas on what i should do im kinda on a budget this year so all i can really do is injectors fuel pump and ecu upgrade the turbo in the car is out of rb25
    Apr 2010
    Regina, Sask
    146
    also i need a new does the programers replace the maf or should i still buy a stock maf
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    550cc Deatschwerks injectors (flow tested, etc with report) -
    http://www.deatschwerks.com/catalog/...roducts_id=114
    Nistune for stock ECU, Z32 AFM + Z32AFM plug with bit of wiring off it (nicknamed pigtail and will need to be wired in), Walbro 255lph fuelpump or Nismo 255lph fuelpump if you can afford it.
    If you do use stock GTR injectors, your still going to have to get them flow tested, etc and not guaranteed that they are all going to not leak and cost you more $$$. Unless they are very low km stock GTR injectors. Also you need to hack up stock injector loom and add ballast resistor pack, as stock GTR injectors are low impedance and stock ECU injector driver is high impedance. Cheaper to get the Deatschwerks injectors that drop in and buy new stock injector O rings.
    Then boost controller (HDI is cheap, HKS, Blitz are more expensive), Clutch (Excedy Sports Tuff clutch???, etc) to handle the extra hp, FMIC (recommend tube N fin HDI FMIC).
    Also full 3" exhaust, Apexi podfilter, BOV (recommend Synapse or similar BOV). On the cheap, mod stock BOV by blocking small hole next to main valve on bottom of BOV.
    Basic boost up mods for stock turbo to produce around 330hp at engine with roughly around 14.5psi.
    Can add Tomei 1.2mm thick 80.5mm bore headgasket, Nissan repair gasket kit, ARP head studs to make engine more reliable.
    Apr 2010
    Regina, Sask
    146
    I have 3 inch exhaust already and modified BOV and boost gauge and rb25 turbo so if im on a budget and want more power whats my best bet??
    GTRCer nelsonmxmarc's Avatar
    Jul 2009
    Montreal
    2,039
    Leave it as is until you have more funds..
    These things come in segments..
    1. Exhaust+intake
    2. Turbo (rb25 only, as most others will need a tune)
    3. Injectors+Maf+fuel pump+tune
    Get nistune for simplicity, but shop around as you may find no one in your area tunes nistune.. So just be keen on that before diving in. Nistune is the most affordable and imo, the best option for our cars.
    So if you're low on funds, just buy things slowly, but when it comes time to install, general rule of thumb is the above go together - injectors need fuel pump, need maf for higher hp numbers, NEED tune.. Otherwise you're just wasting funds on retunes everytime you add something to the equation..
    EBC is a good idea as well, and everything Skym said for reliability.. Not worth cutting corners.
    www.nelsonmx.wordpress.com
    Sep 2007
    South
    6,702
    If can't afford the above and are on a tight budget.
    1.) Cheapest is Nistune + tune cost (dyno rental cost + tuners labour), 255lph fuelpump. Should produce around 290-300hp at engine with 12-12.4psi (with podfilter).
    2.) Or if you can afford it, Nistune + tune cost (dyno rental cost + tuners labour), 255lph fuelpump, Z32AFM + Z32 plug / tail, tube N fin FMIC. Should produce around 310-320hp at engine with 13-13.5psi.
    You have to think, do you want to collect parts and tune it in one go. Or do a tune now (option 1) and then another tune later on (cost's more) when you collect all the parts you need (post above with injectors, etc).
    Also I forgot engine oilcooler, as oiltemps can rise and RB20DET doesn't have a stock coolant to oil engine oilcooler like RB25DET, RB26DETT do.
    Apr 2010
    Regina, Sask
    146
    ok so can i get oil cooler from rb 25?? and o have upgrades turbo and exhaust intake.. so i need injectors maf fuel pump and tune.... i was going to get a stock maf and fuel pump and injectors outta gtr but you guys sayin not a good idea??
    Apr 2010
    Regina, Sask
    146
    also if i went with the 550cc injectors what would i have to do
    Sep 2007
    South
    6,702
    With injectors it's always better to buy new injectors.
    With 550cc injectors you need the 255lph fuelpump, new stock O rings for injectors. Don't use the O rings that are shipped with injectors.
    Never bolted a stock RB25DET coolant to oil engine oilcooler onto RB20DET. But assume it can be done with some rerouting of coolant hoses under intake manifold. But it's better to run a air to oil engine oilcooler than use the stock one.
    Z32 MAF, Nistune, 255 fuelpump, 550cc injectors.
    Apr 2010
    Regina, Sask
    146
    whats ya think thatll cost me
  1. what to expect from upgrades.
    By cortexx in forum GT-R Tech
    Last Post: 09-27-2010, 11:13 PM
  2. injector upgrades
    By linedriver in forum GTS Tech
    Last Post: 10-31-2007, 05:57 AM
  3. Brake Upgrades, and where?
    By clandestine in forum GTS Tech
    Last Post: 04-26-2007, 08:18 AM
  4. Turbo upgrades?
    By mx855 in forum GT-R Tech
    Last Post: 03-09-2007, 08:33 PM
  5. Rad upgrades???
    By Nismo in forum GTS Tech
    Last Post: 03-31-2004, 02:42 PM
