Results 1 to 3 of 3
Thread: Coilover adjustment help needed asap!
    GTRCer sunnypatz's Avatar
    Mar 2011
    Montreal
    120
    Im trying to adjust the height on my coils... i did the passenger front one already, and i got the knob to start turning clockwise (upwards).
    The opposite side coilover, would it turn in the same clockwise direction, or in the opposite direction for the dial thingy to turn upwards? I can't seem to get it to budge in either direction and I wanna make sure im putting all my effort into the right direction lol
    And also would the back 2 be the same also?
    oh and they are tein type he's btw
    1991 Black GTS-T
    Mar 2011
    Montreal
    120
    Also, do I only turn the bottom dial? Or do I have to turn the ones at the top of the coilover as well? Never done this before lol
    1991 Black GTS-T
    GTRCer Ghost's Avatar
    Dec 2010
    Edmonton, Alberta
    127
    The bottom one is a locking ring. You'll need to separate the bottom from the top one and turn the top one. you'll need to eventually move the bottom one to underneath the top one and tighten it against it. Are they brand new or used? f the coilovers are used, might wanna try cleaning the threads a bit and spray a bit of liquid wrench or WD40 to help them to start turning. On mine turning counterclockwise was lowering the rings, clockwise would raise them.
    At least that was my rear ones, never had to adjust my fronts..
    But from what i understand you need to move the top 2 on the fronts together in clockwise to raise...
    You gotta pay to play.
  1. Clutch Help needed ASAP
    By pmurr181 in forum GTS Tech
    Last Post: 05-30-2011, 04:51 PM
  2. coilover needed in toronto ??
    By vincegts in forum Want to Buy
    Last Post: 05-15-2011, 12:34 PM
  3. Timing belt needed ASAP
    By evolution23 in forum Want to Buy
    Last Post: 05-15-2011, 12:54 AM
  4. Tien Coilover Adjustment wrenches
    By playtime in forum Want to Buy
    Last Post: 03-20-2011, 04:23 PM
  5. 20 yr car appraisal needed ASAP
    By judasentinel in forum Legalese
    Last Post: 01-28-2011, 12:50 AM
