Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: starting problem
    May 2009
    winnipeg
    10
    starting problem
    on my way home yesterday my r33 suddenly dropped rpms while i was driving and stalled out, i tried restarting it a few times with no luck. thinking its a fuel problem i changed the fuel filter but no luck getting it started. if and when i do have it running, it dies out again right away, if i try driving it once i get it started it backfires and stalls out within a minute. i cant figure out what it is >.<
    any suggestions anyone? is it my fuel pump or maybe coilpacks?
    cschepp's Avatar
    Jan 2008
    _________________
    4,323
    Could you possibly have done this after a hard pull? I have seen the Gtr blows intercooler pipes off. But I am having a similar problem and know for a fact it is not the piping so I am going to go to the ignitor after a little fiddling with the plugs
    May 2009
    winnipeg
    10
    definately wasnt after a hard pull, i checked all hoses and piping to see if anything came loose. it cranks over but most the time it wont start, if it does it sputters out and stalls again shortly after, thats where im thinking its a fuel problem. do you think the fuel pump would do this?
    May 2008
    Hanover/Kitchener
    277
    Igniter chip my friend
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    Make sure you double check the intercooler piping, including the one under the front bumper (you have to remove the front bumper) before you start replacing parts.
    May 2009
    winnipeg
    10
    i double checked the intercooler piping and they are all secure, i pulled the fuel line just past the fuel filter to see if fuel is flowing and it is, so now i assume its ignition. how would i go about testing to see if its my igniter chip or coilpacks or anything else
    i was also able to get the car startd, after about 20 seconds it stalled out again, after it stalled tried to restart and wouldnt.
    Jun 2008
    1,987
    I doubt it's coilpacks. Chances of them failing all at once is 1 in a million. They usually fail one at a time and cause misfiring.
    Usually you replace the ignitor chip with another one if you know someone around your area. You can probably test the resistance on it, however I have never done it so I dont know if it's useful or not.
    May 2008
    Hanover/Kitchener
    277
    Hey bro sounds just like what mine did with the igniter gone good luck
    May 2009
    winnipeg
    10
    So if that's the issue how do I fix it?
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Depends on which series of R33 RB25DET.
    With Series 1 the igniters are in the ignition module (square looking box) on top of back of engine.
    With Series 2 the igniters are inside each coilpack and ignition module is smaller.
    Why the igniters are inside each coilpack is due to you can turn each coilpack off via Nissan's Consult (handheld diagnostic computer) when checking for faulty coilpacks. On R32, Series 1 R33 you had to remove coilpack cover and unplug coilpacks one at a time to find faulty coilpacks.
    Could be AACV, fuelpump failure, ignition module, CAS, just to name a few.
    But those symptoms do sound similar to a failed ignition module. Usually does it after 10 minutes or so of driving and engine can't be started until ignition module cools down.
  1. Rb25det neo starting problem
    By diehard_skyline in forum GTS Tech
    Last Post: 06-09-2011, 07:38 PM
  2. Starting problem with rb20det?
    By Got2BeBoosted in forum GTS Tech
    Last Post: 03-04-2011, 01:56 PM
  3. Weird squeek when starting / trouble starting
    By kelaog in forum GTS Discussion
    Last Post: 07-10-2007, 02:16 AM
  4. Replies: 3
    Last Post: 03-10-2007, 02:53 PM
  5. help starting problem
    By jdmnewf in forum GTS Tech
    Last Post: 10-09-2006, 03:43 PM
