Results 1 to 5 of 5
Thread: Double blinking turn signal
    mfroese's Avatar
    Oct 2007
    Lower Rainland, BC
    285
    I've lived with it for a while now but want to fix it to avoid cops being nosy.
    Back story:
    I purchased some cheap LED lights back in 2009 from JZGarage (since been banned from GTRC) and the signals were blinking properly. Those died a few months later and I removed them all and replaced with regular bulbs.
    Since I put regular bulbs in my turn signals blink at a double rate of speed BUT my 4 way hazards blink at a regular rate. Is there a resistor under the dash that I need to replace?
    4 door love.
    GTRCer gtst_skyline's Avatar
    May 2011
    Whistler BC
    100
    check to make sure all your lights are working. this happens when one bulb burns out it gives more power to the rest so they go twice as fast.
    mfroese's Avatar
    Oct 2007
    Lower Rainland, BC
    285
    Symptom explained is the only issue with my lights, all lights have been checked and in good working order.
    4 door love.
    GTRCer Ghost's Avatar
    Dec 2010
    Edmonton, Alberta
    127
    One (or more) might not be seated properly in the housing. I had this happened to me 2 days ago, pulled into CT to get new bulb, pulled the turnsignal housing out to see which one was not working. When i pulled the bulbs, all filaments were still intact... "wtf!" i said out loud to my self next to the lady getting into her minivan with her 4 kids... turned out the bigger bulb had shaken loose and wasnt sitting all the way in on the contact.. problem solved... see if that is the issue. You MIGHT have gotten slightly smaller bulbs and they MIGHT be shaking loose or not hitting the contacts properly.
    LED lights, especially the 194 replacements, are slightly bigger and can stretch the contacts apart making the normal ones not fit as tight as before.
    You gotta pay to play.
    GTRCer m_melen's Avatar
    Nov 2008
    The Great State of Texas
    1,779
    Incorrect bulbs can alter the resistance and create problems. I've seen wrong bulbs for an air bag circuit light set off the airbag warning on a dash
  1. need r32 gts turn signal light
    By Snags in forum Want to Buy
    Last Post: 04-12-2011, 01:08 AM
  2. WTB: Right turn signal
    By PapaPump in forum Want to Buy
    Last Post: 05-12-2007, 02:14 PM
  3. WTB: GTS turn signal light.
    By Trace in forum Want to Buy
    Last Post: 02-21-2007, 03:36 PM
  4. FS: Turn signal from my GTS-4
    By genius in forum Parts for Sale
    Last Post: 09-11-2006, 11:05 AM
  5. FS: OEM Turn signal from GTS-4
    Last Post: 09-06-2006, 04:01 PM
