Results 1 to 7 of 7
Thread: Oil Pan removal RB20 skyline?
    GTRCer Got2BeBoosted's Avatar
    Feb 2011
    Medicine Hat AB,Canada
    56
    hello just wondering if anybody knew the best way to remove the oil pan on my on my motor it is in the car still and dont wanna remove it but i have to do it because its leaking bad. anyone know the best way??
    GTRCer m_melen's Avatar
    Nov 2008
    The Great State of Texas
    1,779
    disconnect the engine mount nuts, loosen the tranny crossmember bolts a bit, get a hoist and lift up the engine a little, then take off the 26 or 28 little 10mm bolts that go around the oil pan. FSM recommends taking off the strainer's 2 little 12mm bolts with a wrench while taking off the oil pan to make it easier.
    Nov 2008
    1,779
    oh, and those 2 brackets that bolt the block to the tranny on the bottom might be in the way, can't remember. make sure to wire wheel that oil pan once it's off to get all the 20 year old crap off.
    Feb 2011
    56
    thanks man that sounds a lot easier than just tearing the motor right out to do that cause if thats what the case is than i'm just going to rebuild the bitch!
    Feb 2011
    56
    Oh and what about sensors attached to the harness would i have to remove any of them or am i only gonna be hoisting it an inch or so??
    Nov 2008
    1,779
    Definitely not worth pulling an engine to do an oil pan. You'll need some silicone liquid gasket for that oil pan, and make sure you don't lose the o-ring to the strainer in the pan. Its also gonna be messy so have a good drain pan ready.
    If you've got other leaks and decide you want to do a rebuild then make sure of two things first.
    Have another reliable car to get you to work for a couple months.
    Buy EVERYTHING that you know you'll need before you pull the engine. Thermostat, water and oil pumps, gasket kit, engine mounts and trans mount if they're cracked, etc.
    Nov 2008
    1,779
    And no clue about whether the sensors need to be disconnected or not, but I would if you can. Old brittle harnesses can break easy
  1. Skyline Rb20 Recommended API Oil rating
    By Supraclean in forum GTS Discussion
    Last Post: 04-19-2011, 11:23 PM
  2. A/C Removal
    By deo13 in forum GT-R Tech
    Last Post: 05-06-2008, 05:42 PM
  3. WTB Skyline Guage cluster for RB20
    By YakuzaJeff in forum Want to Buy
    Last Post: 05-02-2008, 02:15 PM
  4. WtB: skyline gts coilovers and rb20 maf
    By drifter.sx in forum Parts for Sale
    Last Post: 11-28-2006, 07:39 PM
  5. AC removal
    By klys in forum GTS Tech
    Last Post: 07-23-2006, 11:22 AM
