This may be a noobish question, but are they journal or ball bearing?
89 Skyline GTR [daily]
89 Skyline GTS-T [sold]
stock is journal
EDIT: i see was wrong, looks like i was mis-informed![]()
1990 Gts-t M
even more noobish.....what is journal ??? First turboed car so be easy :$
Awesome! Thanks for the reply. Journal refers to the type of bearing used inside your turbo on which the center shaft rotates.
Rb20 stock turbo is ball bearing and rb26 is journal. Search here a bit and you will find quite a lot of info on these turbos, especially from skyme.
The info I found said that if there is a spring in the oil return line it is ball bearing, no spring means journal. Is it possible that Nissan used both types on the rb20's?
any question you have try google first, takes seconds and youll find everything
http://www.turbobygarrett.com/turbob...o_tech101.html
http://www.8thcivic.com/forums/turbo...l-bearing.html
A. Nash
