So as I was driving my RB20 today I ran into a very odd problem. I will boost fine up till around 8-10 psi at which point something starts whistling or leaking boost or something and it won't boost any higher. I was boost at 14 psi with my boost controller fine up until this happened. Once I hit 10psi or so, my power drops significantly and it won't boost anymore and that whistling will happen. I tried swapping my bov out for a one I know works fine but that didn't change anything. My spark plugs have under 5k on them but are iridiums (don't know if that matters). Everything is fine up until then. Should I check my ECU for a code? Could it be a broken boost solenoid? Or a broken hose? I am confused and worried for my engine as I don't want to drive it far like this
LinkBack URL
About LinkBacks
