Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Fuel system failure?
    Jul 2009
    Canada
    136
    I came back from the beach yesterday and on my way home the gaz pedal died. I couldnt pass 3k rpm and the car was dieing. I had enought roll to take the first exit. I tried starting the car and it keep shutting even after i pressed to throlle to the 3k rpm limit. Since the car can start but not for too long could there be a fuel system failure somewhere?. Its a rb25 in a r32 chassis and the tuner did rewire the fuelpump.
    Apr 2011
    GTA
    41
    Was the motor warm? I've had this same problem when I drive my r33 without the motor warmed up. This happens even on hot days. In your post it says "first exit". You were most likely on the Hwy........It could be a sticky thermostat and a cold motor. I've never had this problem in my r32 but without fail everytime in my r33.
    This is nothing but a guess. Take it for what it's worth.
    Jul 2009
    Canada
    136
    I tought the same. On a other forum poeple told me it could be a failure from the maf. Would be logic since lately I was running alot more rich.
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    Check your intake piping and all your couplings.
    Jul 2009
    Canada
    136
    UPDATE: I found another maf but it didnt resolve my problem. The car start but idle is bad and lots of smoke come from the back. Iam cluless as for now. Maby a blown turbo or a ecu?
    mfroese's Avatar
    Oct 2007
    Lower Rainland, BC
    285
    Your car is going into limp mode which is a safety check in the ecu. Any codes thrown through a consult cable? Maybe both mafs are shot? Could open one up and re-solder the points in there. Cut the seal around the top square bit to get in. Have you replaced your o2 sensor or spark plugs lately? I'd check the regular wear items first.
    4 door love.
    Jul 2009
    Canada
    136
    The swap is not that old. Iam going to stop by and see the tuner if he could have any advice since he did almost everything.
    GTRCer anthony's Avatar
    Apr 2006
    vancouver island'ish
    952
    have you tried checking the ecu for codes? if it wont go past 3000rpm it would seem it is in limp mode
    the flashing lights should flash you the code if you dont have a consult cable and some sort of software and tell you
    which sensor is giving you grief. your tuner should have a program to help you with that
    Jul 2009
    Canada
    136
    thanks I will be looking for that . Hope it is an easy fix
    Jul 2009
    Canada
    136
    The car is in fact in limp mode. I did a ecu error test and I got 43: tps sensor. I have no clue what cause this and how to fix this. Back on google.
  1. Fuel system electrical help
    By clone in forum General Skyline Tech
    Last Post: 06-04-2011, 08:43 PM
  2. 800hp fuel system....
    By jeff in forum Parts for Sale
    Last Post: 04-16-2011, 07:17 AM
  3. Replies: 14
    Last Post: 03-01-2011, 06:24 PM
  4. Fuel System set up recommandation
    By C-unit in forum General Skyline Tech
    Last Post: 06-19-2008, 08:03 PM
  5. Fuel system leak #3!
    By Bruizer in forum GT-R Tech
    Last Post: 11-09-2007, 12:52 AM
