Results 1 to 6 of 6
Thread: A/f ratio gauge + O2 sensor?
    GTRCer krystalized_jdm's Avatar
    Feb 2010
    Saskatchewan
    172
    Went to go splice this wire in today to find there are 3 wires on my o2 sensor.
    A red, Green, And black wire.
    Which one do I splice this new gauge wire into?
    Also, could you tell me what the other ones are for?!
    Thanks guys!
    - Stephen
    mfroese's Avatar
    Oct 2007
    Lower Rainland, BC
    285
    Widebands should have their own sensor and have the option to relay the reading to your ecu should you put it in the stock o2 sensors hole. Most weld on a bung on the down pipe as the 2 merge. narrow bands are useless IMO. I installed an Aem uego recently and didn't touch stock o2 harness/wires at all.
    GTRCer feyd182's Avatar
    Nov 2006
    Edmonton, Alberta
    697
    It's a heated o2 sensor, one is power, one ground, one signal.
    89 Skyline GTR [daily]
    89 Skyline GTS-T [sold]
    Feb 2010
    Saskatchewan
    172
    Well which wire is which? Thats all I need to know.
    cschepp's Avatar
    Jan 2008
    _________________
    4,323
    I could see red-power,green-signal, black- ground. From what I remember
    Aug 2008
    Edmonton
    347
    You should be putting your wideband around 2 feet down from the turbo on the dump pipe. Cut a hole out and weld in the new bung then wire in your new wide band o2, just leave the old o2 as is because your ECU still needs it to function properly.
    Regards,
    Ken.
  1. WTB - exhaust temp sensor for my Omori Gauge
    By RSi in forum Want to Buy
    Last Post: 12-14-2010, 12:00 PM
  2. wtb water temp sensor for a gauge.
    By RABBIT in forum Want to Buy
    Last Post: 07-21-2010, 11:03 AM
  3. GTR A/F ratio questions?
    By cbileske in forum GT-R Tech
    Last Post: 07-13-2008, 02:30 AM
  4. a/f ratio gauge install
    By Matty in forum GT-R Tech
    Last Post: 12-17-2007, 12:27 PM
  5. Exhaust, O2 Sensor, & EGT gauge question
    By Boyscout in forum GTS Tech
    Last Post: 08-21-2006, 09:10 PM
