Results 1 to 7 of 7
Thread: R32 GTS-t wheel alignment
    Jul 2009
    Victoria
    256
    Please don't hate for this post, so hear me out first!
    I called a few local shops around town (including campus nissan) and either people are not interested in taking the vehicle, or they want me to supply the specs sheet.
    I did a search, and found some information, but most of it is from 2005. That being said all pictures that gave specs are no longer being hosted, and thus being a dead link. Some information was semi useful, but very contradicting. Apparently 240sx specs can be used, but the toe will be slightly off, or I could use any R32 (GTR, GTS-4, GTS-t) specs, or I could use 300ZXTT specs, or GTS-t specs but have everything switched for our LHD roads.
    Logically thinking, the 300ZXTT would be the best bet since its already done for our roads, and its similar in size, but what do you guys think? Can I tell the shop to just use the 300's specs, or should I get actual GTS-t spec sheet, and just have everything switched?
    cheers
    Quote Originally Posted by victoriaGTR View Post
    tire smoke makes my wiener tingle.
    Aug 2008
    Edmonton
    347
    Depends on weather you have adjustable front control arms for changing your front wheel camber to suit our roads.
    Regards,
    Ken.
    GTRCer feyd182's Avatar
    Nov 2006
    Edmonton, Alberta
    697
    I've done alignments on R33's and R32's and the only real thing that can be adjusted is toe. You can however adjust rear camber, but the more negative camber you add the worse your tires are going to wear. Having a spec sheet to go off of makes life a lot easier. I have specs for the R33 GTR, which should be fairly close to the R32. It basically depends on the guy doing the alignment, and remember that there is both front and rear toe. The only real way to get front camber is to either A] buy adjustable control arms, B] slot the holes in the front struts to allow some minor adjustment.
    I adjusted my alignment myself, without a computer alignment machine because my steering wheel wasn't centered. Any decent alignment tech should be able to fix you up and be able to compensate for "road crown"
    Too bad you didn't live here in Edmonton, I'd fix ya up in a jiffy.
    89 Skyline GTR [daily]
    89 Skyline GTS-T [sold]
    Jul 2009
    Victoria
    256
    Very good question! I am running OEM front control arms.
    Jul 2009
    Victoria
    256
    Thanks for the offer, feyd!
    I'm not looking for any sort of tweaking since I am still running OEM coil overs lol. I just have to go for a VI and want to have absolutely all my bases covered prior to heading down to a shop.
    GTRCer nelsonmxmarc's Avatar
    Jul 2009
    Montreal
    2,039
    http://www.risingsunperformance.co.u...pecs/HCR32.pdf
    I post this once a month. Can we please sticky this link and the link for the others; http://www.risingsunperformance.co.u.../technical.php
    They're spot on.. Adjust camber per you're intended use (track, tire fairy.. etc)
    www.nelsonmx.wordpress.com
    GTRCer lord_shadow_tck's Avatar
    Jul 2008
    St-Vallier, QC
    87
    Nice! I had complete info for hcr, hnr and bnr, but that is the thing!
  1. Wheel alignment specs.
    By .Tyline. in forum GTS Tech
    Last Post: 05-22-2007, 02:54 AM
  2. GTR Wheel Alignment
    By Marke in forum GT-R Tech
    Last Post: 02-08-2007, 11:48 PM
  3. wheel alignment...
    By akademiks21 in forum General Skyline Discussion
    Last Post: 11-08-2006, 01:42 AM
  4. Wheel alignment problem
    By gtst20 in forum GTS Tech
    Last Post: 03-05-2006, 06:18 PM
  5. specs for wheel alignment??
    By gtst20 in forum FAQ
    Last Post: 02-27-2006, 03:35 PM
