Results 1 to 9 of 9
Thread: passenger door lock stopped working
    GTRCer BongRips's Avatar
    Mar 2011
    the 204
    299
    so I just realized that my passenger door's lock just stopped working. When I lock the car, I hear the power lock trying to lock the door but it doesn't. The motor and everything is working and the lock "flap" thing on the door by the handle moves but not all the way. Door does not lock from outside or inside. But if I use the key on the door from the outside and turn it to lock and hold it there it will lock while the keys is turned and once I let go of the pressure on the key to get it to center to remove it, it isn't locked anymore. My question is, is the door lock fuucked or is it something small like a hook being unhooked and preventing the lock from catching? R32 btw
    GTRCer R33rr's Avatar
    Aug 2009
    604_LITLAN
    509
    remove door panel and check for the lock rod , it may be jamming from it to move freely . wd40 all the moving parts
    A BIRD ON YOUR HAND ** **** ON YOUR WRIST
    Mar 2011
    the 204
    299
    Thanks
    Mar 2011
    the 204
    299
    WD40'd and greased everything. It super grimey causing it become sticky and stiff. I got it some what working now... Sometimes the power lock will work, some times I have to hold the handle up while turning the key in the lock, but it still manages to lock eventually after a few tries if the power doesn't lock it. I shouldn't need a new lock I think, just need to take it out of there, clean it and put it back together with fresh grease.
    GTRCer Snake556's Avatar
    May 2009
    London, Ontario
    1,959
    Cleaning and greasing should fix 'er up!
    '00 Ford Windstar "Rice Killer"
    1994 Nissan Skyline GTR
    Quote Originally Posted by kengeroo View Post
    Mar 2011
    the 204
    299
    Just have to take apart the whole damn door to do that though haha.
    GTRCer Rides's Avatar
    Apr 2011
    Ontario
    72
    I had this problem awhile ago. Take off the panel and use some wd40 on the rod. It'll fix it. It's working because you still hear the mechanism trying to lock it. If it unlocks but won't lock, there should be a screw that holds the two rods together, make sure the screw it tighten. This can come loose if you were trying to unlock your car during cold weather.
    Godzilla - 哥斯拉 - ゴジラ - گودزیلا - Годзилла - גודזילה
    Mar 2011
    the 204
    299
    After the grease had a chance to soak all day in the heat it's actually all working again, for now. Still covered in dirt and grime though. But problem solved for now and hopefully for good. Thanks for the advice people.
    Apr 2011
    Ontario
    72
    Very glad to see it working again.
  1. R32 4 Door Passenger Side Front Door
    By Stiky in forum Want to Buy
    Last Post: 05-31-2011, 08:51 AM
  2. Passenger window not working
    By BongRips in forum GTS Tech
    Last Post: 05-15-2011, 02:50 PM
  3. Driver side wiper stopped working :(
    By aN4rk1 in forum General Skyline Discussion
    Last Post: 09-13-2010, 08:37 PM
  4. Sticky passenger side lock...
    By gunMENTAL in forum GT-R Tech
    Last Post: 01-31-2007, 12:12 PM
  5. power window stopped working
    By GT-Rob in forum GTS Tech
    Last Post: 03-29-2006, 11:29 AM
