Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Possible LIMP Mode?
    GTRCer Madskyline's Avatar
    Jun 2010
    Etobicoke
    71
    Possible LIMP Mode?
    rb20det
    so on a hot day a couple days back i was at a light idling and the car just started to sputter and shake, when i went to accelerate it had a weird popping noise from exhaust and loss of power some black smoke from exhaust and it just went away.
    drove for a bit longer and problem came back this time it did not go away, i was close to home so took her easy, upon arrival i noticed smoke coming from engine bay, popped the hood and at the rear of the valve cover it was spitting out oil. i then noticed that the rear screws on the valve cover were starting to undo themselves(i could turn them by HAND!) so i tightened them and problem went away....for 2 days then it started again rechecked the screws and they were fine. any ideas boys?
    Jun 2010
    Etobicoke
    71
    just installed new valve cover gaskets. dint seem to do the trick, this usualy happens after the cars been driving for over an hour! help would be greatly appreciated.......also does anyone know how important the valve cover screw grommets are?
    Supraclean's Avatar
    Jun 2009
    Grande Prairie
    1,162
    Does your car still have a stock cat? Type this problem into google man there are tons of threads on here regarding this.
    My guess is you stock cat is pluged, if not there are a list of things you can check. Thoe valve cover gromets might be only part of your problem. They are important because it seals you valve covers on that keep oil in your head... also if its not sealing you gonig to have low oil pressure = bad.
    92 Gtst/Silver bullet
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Check the PCV valve. If blocked (needs to be cleaned) or faulty, could be overpressurising and creating the leak.
    The grommets, half moons, gaskets should be replaced. Also liquid gasket applied to halfmoons before install and front, back of head on intake, exhaust side where gaskets go before installing cam covers on engine. If the grommets are crushed, screws can start to undo and leak in that area.
    I think used Permaseal? camcover gasket kit (comes with grommets, half moons, gaskets) on my car. The Permaseal grommets look like a better design than factory. It hasn't leaked since using that kit.
    Jun 2010
    Etobicoke
    71
    so check PCV and shes still rattling....no leaks around the valve clover and it was fine for about a week and started again, i know about clogged cats but this problem is so once in a while it cant be a clogged cat, or evan a vacume leak? car runs great for a while starts bogging down then after letting engine temp cool problem goes away
    Jun 2010
    Etobicoke
    71
    if anyone has a scanner maby we could meet up.....THANKS guys!
    Sep 2007
    South
    6,702
    Missing can be coilpack leaking charge or airleak near MAF (stutter, similar to coilpack problem and is usually the intake hose clamp on MAF or crack inbetween ribs on rubber intake pipe behind MAF).
    The missing with coilpacks is the engine running on 5 cylinders intermittently, then starts running on 5 cylinders permantly when coilpack is leaking alot. Grey tracking marks on both sides of coilpacks under mounting bracket is a sign of them them leaking charge. Coilpacks should be replaced every 100,000km and cause of coilpack failure is using incorrect sparkplug gap when upping boost level, incorrect heatrange or just age. Coilpack loom is another cause of missing (should be replaced as part of routine maintenance). Same with injector loom.
    Jun 2010
    Etobicoke
    71
    iv done some reading and get mixed anwsers whats the proper gapping for 10-12lb boost?
    Sep 2007
    South
    6,702
    Factory gap is 1.1mm and use a NGK PFR6A -11 (-11=1.1mm gap) plug gapped down to 0.8mm for intake, exhaust, BOV which should produce around 250hp (engine) at around 12psi, up from factory 215hp. Some gap sparkplugs to 0.8mm or less due too weaker coilpacks.
    Factory sparkplug for RB20DET is NGK PFR5A -11.
    Jun 2010
    Etobicoke
    71
    ok so new maf dint do the trick and the boot behing it seemed to have no cracks, all coilpacks look fine and no grey markings would make me feel that there not the problem. the loom seems to look in good working order......anything else? at a stand still here guys....thanks for the help so far!
  1. Limp Mode.......need help & advise!
    By 326_godzilla in forum GT-R Tech
    Last Post: 10-06-2011, 05:29 PM
  2. cas sensor limp mode ????
    By gtrjon in forum GT-R Tech
    Last Post: 03-20-2011, 11:17 PM
  3. r33 Gtr limp mode?
    By cory in forum GT-R Tech
    Last Post: 12-18-2010, 01:07 AM
  4. gtr limp mode - now not starting... help :/
    By thieves in forum GT-R Tech
    Last Post: 11-29-2010, 04:53 AM
  5. Limp mode?
    By Mitch01 in forum GTS Tech
    Last Post: 03-27-2007, 07:33 PM
