Results 1 to 3 of 3
Thread: rb25 swap into r32 using rb25 ecu and loom
    GTRCer whiteboy87's Avatar
    May 2008
    calgary
    387
    so i found this on skylines australia
    http://www.skylinesaustralia.com/for...e/page__st__60
    on the 4th page there is kind of a how to if you will of how to wire in the rb25, what i dont really get is when you look at the word document there is pin out information but then after the 12 pin plug it says "RB25 incabin plug wires (cut off plug)" anyone have any idea if this is referring to the plug that he says is a spare? anyone else care to chime in on their experience wiring it in? i want to retain the rb25 ecu because i want vct to work.
    GTRCer chickenLittle's Avatar
    May 2011
    home
    43
    lol i ust did this ok so on your rb20 harness there are 2 fairly small plugs in the passenger footwell as well as one yellow one that has the wiper and rb20 fuel pump resistor wired to it i think you need to cut thos 3 plugs off of the rb20 harness if you need a pic of the the plugs i have it wired into my rb25 harness and the spare plug is the long yellow one that isnt pluged into anything on the r32 it has ike 9 wires on it or somthing the other yellow one has like 4 i know theres an orange solid wire thick as well as a white and black on on the one you (the white and black wire go to the fuel pump resistor)
    GTRCer 92GTSTproject's Avatar
    Jan 2012
    GRANDE PRAIRIE, AB, CANADA
    39
    or you could use the stock harness swap the 2 injector pinouts on the ecu and not have to worry about anything at all... it will only save you about 6 hours of screwing with wires.... just sayin also youll need a diferent speedo sensor
    TO GRIP OR NOT TO GRIP.... THAT IS THE QUESTION
  1. rb25 swap
    By silviak91 in forum General Skyline Discussion
    Last Post: 07-07-2008, 08:32 PM
  2. RB25 SWAP help
    By S13_MPH in forum GTS Tech
    Last Post: 05-03-2008, 05:08 AM
  3. RB25 swap...
    By Nissmo_R32 in forum GTS Tech
    Last Post: 01-14-2008, 08:29 PM
  4. RB25 swap
    By judasentinel in forum GTS Tech
    Last Post: 07-03-2007, 08:11 PM
  5. wtb: rb25 swap or a mint rb20 swap
    By NISMONEWF in forum Sponsor Forums
    Last Post: 04-02-2007, 09:44 AM
