Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: Is ~400whp realistic with this?
    GTRCer BongRips's Avatar
    Mar 2011
    the 204
    299
    Ok so I am in the works of upgrading my car and am making a list for spring. Would I be able to make around 400whp off my rb20 fairly safely with the following mods?
    •aftermarket low mount turbo manifold
    •ws-0448b turbo (rated at 440hp and I know a couple ppl making 350-400whp off them on rb20s and 25s)
    •divorced dump pipe
    •3" dump pipe and decat
    •3.5" catback
    •fmic
    •front facing plenum with 90mm throttle body
    •550cc deastchwerks injectors
    •300lph deastchwerks fuel pump
    •haltech platinum pro ecu
    •stage 2 clutch
    I'm pretty sure that's everything I have written down so far for related mods. Some I have, some is installed and some I have yet to purchase, but back to my question, will my engine make a fairly reliable 400hp with that?
    GTRCer Shane_H's Avatar
    Jul 2010
    Maple Ridge
    214
    in before Mike Kwon (M13) answers everything you need to know.
    1993 GTS-T 4 Door Type M
    3" autobahn 88 downpipe & testpipe
    3" HKS High-power cat back back
    HKS SSQV
    XS Power FMIC
    Mar 2011
    the 204
    299
    how did you hook up your temp sensor in your autobahn 88 decat? I got the same thing and it seems like the hole in it is way larger than the screw on the temp sensor
    Aug 2008
    Edmonton
    347
    I'd upgrade your oil pump, and maybe your water pump aswell. Oil cooler is good if your gonna track it. Bigger radiator wouldn't hurt.
    Regards,
    Ken.
    Supraclean's Avatar
    Jun 2009
    Grande Prairie
    1,162
    Personally I would go with a stage 3 clutch, and you will also need a FPR sir.
    92 Gtst/Silver bullet
    Banned
    Oct 2010
    Mallorytown,Ontario
    1,024
    ull make 400whp..but it wont be reliable..my tuner told me 400 whp on a 20 with no internal work..is unreliable..im shooting for 350whp..
    Dec 2009
    Mississauga,On
    163
    Im pretty sure this is a GTR not gtst. You should make your 400 no problem
    Dec 2008
    GTA
    440
    Quote Originally Posted by Bignoga View Post
    It's an RB20, not RB26
    rak123's Avatar
    Dec 2008
    Winnipeg
    494
    If u want to make 400hp out of your rb20 your gonna need a generous amount of boost and If your running 14+psi u will need a metal head gasket and arp head studs to prevent head lift and your head gasket blowing out.
    Banned
    Oct 2010
    Mallorytown,Ontario
    1,024
    off my rb20 , didnt no GTR came with RB20's ................................................fa il..
  1. Replies: 25
    Last Post: 11-20-2007, 05:01 PM
