Results 1 to 5 of 5
Thread: Probably a dumb question with the simplest solution but I can't figure it out!
    GTRCer BongRips's Avatar
    Mar 2011
    the 204
    299
    Talking Probably a dumb question with the simplest solution but I can't figure it out!
    Getting ready to install my fmic and I notice a lot of ppl use the hole where the horn is for a top bolt hole. When I put the fmic there I'll have to move the two horns right? And if so, where? The play on my cord isn't much at all but appears to be just on wire going to each. Can I splice in some more wire to make it longer and then attach one on each side of my rebar tucked out of the way? Is that possible or will the horns not work anymore? I know this is a noob question probably, but I just dont wanna **** anything up
    GTRCer gtst_type_m's Avatar
    Sep 2009
    kelowna bc
    112
    extending the wires for your horns wont affect them, make sure they have ground tho
    93 laser sold
    91 skyline gtst totaled
    92 skyline gtr current
    Mar 2011
    the 204
    299
    The mounting bracket is what grounds them right? So say I were to do what I said and put them attached to the backside of the rebar, as long as the mounting bracket is screwed onto the rebar it should be grounded right? Or do I have it wrong lol
    Sep 2009
    kelowna bc
    112
    by the ''rebar'' do u mean the tow hooks? and how do u plan on attaching the brackets to them? regards to that yes the mounting bracket is essentially the ground for the horn
    93 laser sold
    Aug 2008
    Edmonton
    347
    Quote Originally Posted by gtst_type_m View Post
    You have oem front tow hooks? Lol
    Regards,
    Ken.
  1. Replies: 16
    Last Post: 07-13-2011, 06:08 AM
  2. quick dumb question
    By nbskyline in forum GT-R Tech
    Last Post: 09-26-2010, 03:35 PM
  3. maybe a dumb question
    By SkylineBoy in forum GTS Discussion
    Last Post: 04-15-2007, 02:06 PM
  4. could be a dumb question
    By jdmnewf in forum GTS Discussion
    Last Post: 01-28-2007, 03:56 PM
  5. Figure 8 Drifting!!!!
    By canadianskyline in forum General Skyline Discussion
    Last Post: 09-28-2005, 08:17 PM
