I am so friggin close. As of right now:
ECU has power.
Fuel pump has power and primes.
Coils, Injectors, VCT, CAS all have power.
CAS triggers injectors.
So it should fire.
Now, when I turn the key to the START position, nothing happens. ACC circuit does not shut off, it doesn't crank. When I turn the key to start, I can hear the starter relay under the dash click. Only, if the deck is off. Once the deck is on. No More Starter Relay... I checked the start signal wire. I tested it, it only gets 12v when the key is turned to start. It is hooked to the green w/black stripe wire as per the wiring guide. I have checked, and all the other 12v wires behave as they should (on/starts stay on at start, constants are constant). ECU is grounded. I am lost from here though. Any suggestions?
LinkBack URL
About LinkBacks
