Read Marcs build, he got those numbers with the proper support mods/ stock exhaust manifold.
Nelsonmxmarc 1993 GTSt Type-M Build / Tips-tricks for HCR32 (Skyleezy!)
If you ask me you have to consider what you can afford.
Are you topmounting this turbo or stock manifold?
If you go topmount most as plumbed for external wastegates so you will need to get the proper WG
Twin scroll manifold + twin scroll turbo will spool up faster then regular T3 flanged BB turbo/,manifold.
This is my Rb20 with supporting mods/ Topmount T3 manifold / Gt2871r Garret turbo with .63ar
Supraclean's "Drift Sicle" Project
I list every mod I have and will upate with dyno graph
I made 341hp at 13.5 pounds of boost, this should give you a good Idea of options you have between Marcs and my build.
If you want even more power! Check out M13s build he is rocking a gt3071 garret turbo:
White 'rine project
