Results 1 to 5 of 5
Thread: Air Filter Adapter question
    GTRCer BongRips's Avatar
    Mar 2011
    the 204
    299
    Hey all. I am in the process of getting all the parts I need for a turbo swap and the one final piece I'm down to is the air filter. Currently I have a ARC Super Induction Box on it which is great except for the fact that my silicone hose coming off my turbo is shaped a bit differently so an Apexi intake or something similar that has the filter on the end of the MAF would work fine in it's place because there's enough room for a filter in place of my box. My question is, for the air filter adapter, are there any other cars that use the same bolt pattern on the MAF to bolt it to the filter box like a 300zx or s13? Because I've seen the Apexi kits for around $100 which isn't bad at all but since all it is is the adapter and filter I figure I could buy an adapter for a different car for cheaper assuming it works and then get a filter. So would a 300zx or s13 filter adapter work?
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Apexi airfilter bolts onto MAF with a gasket. It's not a clamp onto adaptor airfilter.
    There's 2x kits, one with a brace, gasket, etc (more expensive) and one without brace (replacement type airfilter with gasket, etc and is cheaper). It's cheaper to make your own brace out of a strip of metal and buy the replacement type airfilter.
    Mar 2011
    the 204
    299
    would something like this work?
    http://www.ebay.ca/itm/90-96-300ZX-Z...item1e6211a7f1
    It seems to be the same shape as the maf on the rb20 and appears that it would bolt on with gasket. I got a 3" filter kicking around too so I'd just need to spend the $15 for that if it fits. Anybody know?
    Sep 2007
    South
    6,702
    If intake hose clamp comes loose on that adaptor, can cause ECU to hit boost / load cut. Bolt on Apexi airfilter is better.
    GTRCer Nismo_line's Avatar
    Nov 2009
    204
    1,501
    i have been running an adapter like that for 2 years and have never had a problem
  1. RB20 M's K&N Filter + Adapter / RB20 MAF
    By nelsonmxmarc in forum Parts for Sale
    Last Post: 03-24-2011, 11:35 AM
  2. Oil filter Adapter plate
    By RHDskyline in forum Parts for Sale
    Last Post: 03-17-2011, 04:04 PM
  3. Replies: 20
    Last Post: 02-11-2011, 12:43 AM
  4. oil filter relocation kit question
    By MikeyRHD in forum GT-R Tech
    Last Post: 07-28-2008, 08:52 AM
  5. Oil Filter Relocation Question?
    By CanadianGTR in forum GT-R Tech
    Last Post: 01-30-2006, 01:01 AM
