Page 7 of 7 FirstFirst ... 567
Results 61 to 65 of 65
Like Tree1Likes
Thread: Tune up Guide RB20DET GTS-T
  1. #61
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    0.8mm is best for sparkplug gap and one heat range colder if boost level is upped. Stock is NGK PFR5A, 1.1mm gap for RB20DET and PFR6A is one heat range colder with 0.8mm gap. If boost level is turned down and engine runs richer (cooler cylinder temps), might need a hotter heat range sparkplug. But pull sparkplugs and read the tips to see if tips are getting burnt (too hot heatrange) or getting fouled? (too cold heatrange). Learnt the lesson the hard way by burning tips of stock PFR5A sparkplugs with basic intake, exhaust and took out 2x coilpacks with using incorrect replacement sparkplugs.
    I would suggest you read the FAQ section on NGK website to learn about heatranges -
    http://www.ngksparkplugs.com/tech_su...x.asp?mode=nml
    Nistune for stock ECU. Once Nistune is installed inside stock ECU, makes stock ECU retuneable via consult plug (under dash on drivers side, next to fuses), consult cable, laptop, tuning software. Next set of mods would be FMIC, fuelsystem upgrade (stock injectors are good for roughly around 276hp at engine), Z32 MAF + Z32 MAF plug (needs to be wired in), boost controller, clutch upgrade.
  2. #62
    GTRCer BongRips's Avatar
    Mar 2011
    the 204
    299
    I'm not 100% for sure if the boost is upped, but from what I've read, RB20DET boost at ~7psi stock and in 3rd - 5th I boost around 10psi (gauging from the stock boost gauge needle being halfway between 350 and 700mmHg) I know it has an ARC intake and I'm pretty sure cat-back exhaust, possibly just axle back. So would I be using the PFR6A .8mm gap then? or could I go to a .9 mm gap. I need advice as this is the first car I have owned that's turbo and that I'm tuning.
  3. #63
    Sep 2007
    South
    6,702
    PFR6A with 0.8mm gap should be enough. But with colder conditions, cooler cylinder temps, factory heatrange might work. But reading the tips of current sparkplugs is the best way to determine what you need with heatrange. Also a Nissan dealership that sells Skylines (mechanic) usually can recommend a plug to use for conditions.
    How you figure out how much to gap sparkplugs is mentioned on the NGK website under FAQ -
    http://www.ngksparkplugs.com/tech_su...p.asp?mode=nml
  4. #64
    Mar 2011
    the 204
    299
    I've been looking around winnipeg for a set of spark plugs to install when I install my boost controller, but I can't find plugs pre-gapped at .8mm anywhere. Do they even exist or do I need to gap myself? The plugs I'm looking for is BCPR6EIX-8 but can only find BCPR6EIX-11
  5. #65
    Sep 2007
    South
    6,702
    Can regap them, but read the part in above link about gapping sparkplugs that mentions what to watchout for when regapping those type of sparkplugs.
    I think it's a special part number and are pregapped to 0.8mm. Has no -11 or -8 on the end. Or just get NGK copper sparkplugs, regap and change them every 10,000km or so.
