Results 1 to 5 of 5
Thread: Please help car wont stay running!
    GTRCer Got2BeBoosted's Avatar
    Feb 2011
    Medicine Hat AB,Canada
    56
    Unhappy Please help car wont stay running!
    Hello i was just fixing one of my grounds on my boost controller that was not working and then i started my car right
    after and it would not start it has fuel and spark for sure all the fuses are good, I have reset he ECCS twice its a
    RB20Det skyline ran perfectly fine before i was fiddling with it and now i have come across the problem that the car will
    run. When i put my foot to the floor and
    hold the the ignition to on and it cranks for a second than starts but dies.. it stays running if i hold the gas to the floor
    and keep it cranking than it starts but i can hear the starter still spinning well it is running and when i stop it from
    cranking it it quits like i shut the car off so the starter cranking the engine is the only thing keeping the car running.
    The car had and has no trouble starting ever before this problem.
    I have read the codes and it says 55 OK and i checked that the plugs where not fouled even and everything is good
    that i can see.
    i cannot figure out the problem whatsoever i am stumped any suggestions would be really great please chime in
    thanks,
    GTRCer feyd182's Avatar
    Nov 2006
    Edmonton, Alberta
    697
    Did ya try to remove the wire you fixed to see if it will run? Seems odd that fixing a ground wire would cause a "no-start" condition. Maybe your fuel pump crapped out?
    89 Skyline GTR [daily]
    89 Skyline GTS-T [sold]
    Sep 2010
    Edmonton
    44
    TPS sensor going out? That'd be my guess. Could be MAF, but it should still start.
    Feb 2011
    56
    Well i figured it out like 2 hours after i it all happened it turns out that where i had the ground wires for all my electronics were near my main ignition steering column harness and i had pulled the blue ignition ON wire out of its terminal on the steering column so it had no
    power whatsoever but the ignition Start was still touching so it had worked i fixed it now thanks for trying to help though i was so
    stumped for awhile.
    Nov 2006
    Edmonton, Alberta
    697
    Pulled your wire a little too hard eh? Lol. J/K. Glad you got it solved.
  1. Please help car wont stay running!
    By Got2BeBoosted in forum GTS Tech
    Last Post: 09-10-2011, 07:36 PM
  2. Replies: 3
    Last Post: 04-05-2011, 06:31 PM
  3. t-belt wont stay straight!!!
    By Dan-o in forum GTS Tech
    Last Post: 07-12-2008, 02:06 PM
  4. HELP!-Car doesn't stay on
    By d-mcisaac in forum GTS Tech
    Last Post: 11-03-2006, 08:27 AM
  5. Anyone else not able to stay logged in?
    By Daemos in forum General Skyline Discussion
    Last Post: 04-13-2004, 02:10 PM
