Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Do I need aftermarket gauges?
    GTRCer BongRips's Avatar
    Mar 2011
    the 204
    299
    So I'm starting the build on my car in the spring and trying to keep it as stock looking as possible. So my question is do I really need aftermarket gauges in my car? Now I know that stock gauges are basically idiot gauges but after all the tuning is done via the haltech ecu, since all the stats are on there, do I really need gauges in my car while I'm driving it?
    Banned
    Oct 2010
    Mallorytown,Ontario
    1,024
    well if u wanna run more than 7lbs you wil need a boost gauge for sure cuz you wanna no what your boost is 100%. I would also suggest water temp because the stock ones dont tell you the temps so you wont know if your car is running 180 or if its running 220 . Also a oil pressure gauge, thats self explanitory and once again stock isnt always accurate.. I would at least get those 3 .. Personally I love the gauges I bought by STRi and for the price you cant go wrong, dont think i paid over $100 for each gauge and theyre very accurate. Just my 0.02
    Mar 2011
    the 204
    299
    Well if I need to run gauges it'll be oil pressure, boost, egt, and an aem wideband. That should be good enough to monitor everything necessary right? I just really don't wanna run aftermarket gauges and keep a clean inside but I guess I need them for safety haha
    Banned
    Oct 2010
    Mallorytown,Ontario
    1,024
    id run a water temp too just to be safe..you can get clean vent deletes or dash mount like mine ..same as this pic
    some guys also move there radio and climate control down and throw them up there like the GTR's
    [IMG]<a href="http://photobucket.com/images/r32%20skyline%20vent%20delete" target="_blank"><img src="http://i302.photobucket.com/albums/nn94/Nelsonmxmarc/DSC_0059.jpg" border="0" alt="r32 skyline vent delete Pictures, Images and Photos"/></a>[/IMG]
    vetn deletes
    Marc Nelson makes them for cheap aswell (youre welcome nelson, if you see this
    http://nelsonmx.wordpress.com/servic...gtrgtst-parts/
    Aug 2008
    Edmonton
    347
    You won't need a EGT if you're running a wideband, they're basically showing the same thing. The wideband does the AFR math for you.
    Regards,
    Ken.
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,113
    btw the stock boost gauge goes up to 13,5psi not 7
    Banned
    Oct 2010
    Mallorytown,Ontario
    1,024
    im an idiot forgot its mmhg
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    If you do any kind of hard driving, I'd have a water temp gauge. Water temp can be indicative of oil temps, but you can run both if you want to know exactly what both are. Make a mount in the glovebox and open it when you want to have the info available, keep is closed when driving normally to retain stock look.
    Edit: People think that an EGT gauge isn't important, but I disagree. A wideband will tell you air fuel ratios, but won't tell you egt's, especially if you're unsure of ignition timing. Richer afr's with advanced timing will produce lower egt's, while leaner afr's with less timing will create hotter egt. It's just another thing that's good to know, imo.
    GTRCer clone's Avatar
    Aug 2010
    Caledon
    226
    The only aftermarket gage I have is A/F. mainly because when I first got the car I dynoed it.
    My datalog showed I was running Lean. Now I corrected that problem and constantly monitor it.
    Dec 2007
    Quebec
    3,209
    sure you do and you should buy my matching set of 4 stri gauges. iol temp water temp, boost and oil pressure!
    Ovechkin is the best player.
  1. gauges you use
    By Nexsys in forum General Skyline Discussion
    Last Post: 07-19-2010, 08:56 PM
  2. best gauges to get?
    By meow in forum GTS Discussion
    Last Post: 06-14-2007, 11:45 AM
  3. wtb: megan racing gauges, or any tinted gauges available
    By skyline_guy777 in forum Parts for Sale
    Last Post: 11-03-2006, 11:34 PM
  4. Most Useful Gauges
    By RaceBred in forum General Skyline Discussion
    Last Post: 06-26-2005, 09:55 PM
  5. ECU/Gauges
    By kaze in forum GTS Tech
    Last Post: 06-22-2005, 11:57 AM
