Results 1 to 4 of 4
Thread: rb20 base map for haltech platinum pro?
    GTRCer BongRips's Avatar
    Mar 2011
    the 204
    299
    Anybody got a base map or any map I could modify for an rb20det running a haltech platinum pro ecu? I know their site says to swap pins 112 and 114 on the factory harness to run it on an rb20det or rb25de, but the only base maps I found were for rb25det and rb26dett. Any help would be awesome
    Mar 2011
    the 204
    299
    Anybody got any advice? Should I use the rb25 map but change the displacement and injector size and what not?
    Supraclean's Avatar
    Jun 2009
    Grande Prairie
    1,162
    I take it your planing on geting a tune? Just make sure it idles ok and trailer your car there. A lot safer and less hassle I think if anything were to go wrong.
    92 Gtst/Silver bullet
    Mar 2011
    the 204
    299
    Installed it today, uploaded the rb25 base map, then changed the engine displacement to 1998cc and injector size to 270cc, that's all. Oh, and of course I swapped pins 112 and 114 before doing this too. So I loaded the map and turned the car on and the idle was beyond erratic and lumpy. It would idle between ~800-1000 rpm and not stick to one at all. No fault codes were thrown off though. Also, my injector duty cycle was going into the -2000s-3000s and that was flashing red. What do I have to change to get this to run properly???? Or, does anybody got a base map that I could use???
    Car idles fine on stock ecu and runs fine on no boost btw
  1. Replies: 1
    Last Post: 10-05-2011, 03:06 PM
  2. Replies: 0
    Last Post: 09-28-2011, 06:04 PM
  3. FS/FT: Haltech Platinum Pro plug-in ECU
    By Hauer in forum Parts for Sale
    Last Post: 08-16-2011, 07:42 AM
  4. Haltech platinum pro and Power Fc
    By ruthere in forum Want to Buy
    Last Post: 10-09-2010, 03:39 AM
  5. Haltech Platinum Pro R32
    By Bee-RSkyline in forum Want to Buy
    Last Post: 08-27-2010, 06:03 PM
