Results 1 to 9 of 9
Thread: RB20 Ultra Lean. Please help!
    Oct 2011
    Iowa
    2
    I need the help of the RB engine masters. Car is idling a little high and is very lean. Here's all the details.
    At idle, wideband reads off the charts, 18:1 +.
    If I unplug the MAF, car idles at around 11:1.
    Tried a different MAF, no change. Checked voltage of MAF at ECU, showed 1.3v, with light throttle, went up to 2v. Seems to be okay.
    Checked very diligently for vacuum and air leaks. Boost gauge shows vacuum at 20. Seems good.
    Tried a different o2 sensor, no change. Checked the voltage at the ECU, showed around .5v when the MAF was disconnected (running rich), shows 0-.1v with the MAF connected (running very lean). Seems to be okay.
    Checked ECU for error codes. Showed 55, all good.
    Put fuel pressure gauge between fuel filter and fuel rail. Showed around 40 psi. Seems good.
    I read on this very site that someone had their engine run lean due to the engine temp sensor, which seemed completely insane, but I tried unplugging mine, as that poster did. No change.
    I'm really out of ideas. Maybe the ECU was tuned for larger injectors? Maybe there is some sort of nearly invisible vacuum leak. I've checked all around, and you would think it would need to be a decent leak to make the car this lean.
    Considering the 11:1 ratio with no MAF, is it even possible that it is related to the injectors/coils/spark plugs? I'm starting to hate this engine
    Please, please, please help me.
    -Rob
    GTRCer nimblestix's Avatar
    Mar 2007
    Maple Ridge
    502
    Is it misfiring at all? When you rev the engine does it richen up?
    Sent from android using Tapatalk
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Checked wiring to fuelpump???
    Check that there is no exhaust leaks as oxygen in exhaust (leaking exhaust manifold, common problem) = lean on wideband.
    Same with intake plenum airleak (common problem, engine runs lean), but would have rev needle bouncing up and down due to o2 sensor making engine go lean, rich (when leak is really bad).
    Higher idle points towards IACV, that's where I would look.
    With narrowband o2 sensor your meant to hold at 2000rpm? and note how long it takes to switch between lean, rich voltage wise.
    GTRCer clone's Avatar
    Aug 2010
    Caledon
    226
    Just curious, What fuel pump are you running?
    Jul 2004
    St. John's,NEWFOUNDLAND
    739
    what fuel pump has nothing to do with it .... if the rb is in a 240 and hes using the 240 fuel pump then it shouldnt be a problem unless hes running a much larger turbo ... and thats only when showing boost ... im with Skym on this one .... all of those are possible .. i have seen each and every one of those problems on many RB's .. its been a few years since i have turned a wrench on an RB but you never forget those pain in the ass leaks ....
    http://www.cardomain.com/ride/2400117
    1989 skyline gts-t .. the slut ..
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,055
    find the issue???
    A. Nash
    GTRCer Sharkus29's Avatar
    Jan 2011
    Alberta
    134
    Maybe your widebands messed.
    GTRCer supersayianjim's Avatar
    Apr 2010
    saint joseph m.o.(u.s.a.)
    162
    if hed running a rb20 i would hope hes not using a stock ka fuel pump!!
    Aug 2010
    Courtenay , BC
    1,055
    Quote Originally Posted by Sharkus29 View Post
    ya but if the cars running like sh*t then there's probably actually an issue somewhere
    A. Nash
  1. ULTRA Multi Mode Meter Plus
    By Like_A_Sum_Bootay in forum General Skyline Tech
    Last Post: 08-21-2011, 07:26 AM
  2. Lean rb20
    By wongger in forum GTS Tech
    Last Post: 09-21-2010, 11:25 PM
  3. FS: 205/75R15 Goodyear Ultra Grip Snowtires $160
    By wink1100 in forum Parts for Sale
    Last Post: 10-29-2007, 11:01 AM
  4. F.S. Ultra-rare Jun grill BNR32
    By Daryl @ RightDrive in forum TunerLab.jp
    Last Post: 10-27-2007, 11:47 AM
  5. F/S Autometer gauge 2/16 Ultra-lite **Pic**
    By nickR32 in forum Parts for Sale
    Last Post: 11-27-2006, 09:30 PM
