Results 1 to 9 of 9
Thread: Clutch...stopped working
    GTRCer 604_R32's Avatar
    Jun 2011
    Maple Ridge, BC
    134
    So I'm at a redlight and I go to put my car in first, except it wont go into gear, and I realize my pedal is on the ground and it wont come up. No pressure at all in the pedal.
    Guessing its the Master or Slave cyl? If I am right, I can use S13 240sx ones correct???
    Jun 2011
    Toronto
    1,562
    Its amazing how this is happening to everyone all at once. Exact same happened to me two-three weeks ago, except I was blocking lots of traffic, and let's say it wasn't a good day.
    But yes, two things to replace: master cylinder and throw out bearing.
    Because race car.
    GTRCer -Jay-'s Avatar
    Jan 2006
    Calgary
    565
    Why throwout bearing?
    It's probably your clutch master be could be the slave. Do you have fluid leaking down the pedal or signs of leakage by the master? If so, start there, if not check the slave on the side of the transmission.
    91 GTST Type M
    Jun 2011
    Maple Ridge, BC
    134
    My Throw-Out bearing was making sounds when I bought the car, would that finally going cause the pedal to do this. I still have plenty of fluid in the resivoir, and theres no fluid on the floor and no leakage by the master.
    Guessing its the slave?
    GTRCer feyd182's Avatar
    Nov 2006
    Edmonton, Alberta
    697
    Slave or throw out is stuck on the input shaft. Pull the rubber boot back on the slave and if you see brake fluid, it's toast. Not sure about the GTS's, but the 240 slave will not fit my GTS-4 at all. It is a totally different cylinder made for a LHD, so the bleeder is on the bottom which means it will never bleed.
    89 Skyline GTR [daily]
    89 Skyline GTS-T [sold]
    Jun 2011
    Maple Ridge, BC
    134
    The Part number for the GTST and the GT4 are completely different.
    That being said, does the 240 one fit an R32 GTST. And I know the master is slightly different, but if you get a new hardline along with the Master, it works.
    GTRCer iwannagofast's Avatar
    Jun 2011
    kamloops, b.c.
    70
    nissan pathfinder for the master apparently. not sure which year. 240sx or 300zx should work for the slave.
    Nov 2006
    Edmonton, Alberta
    697
    91 Pathfinder for brake master. But watch out its expensive, locally it's $200.
    Jun 2011
    Maple Ridge, BC
    134
    ^ Do you mean clutch master lol.
    And yea, Nissan said its my slave, which was pretty obvious since my masters fine still. Oh well, Ill fix it today
  1. Ontario Re-Vin program stopped for SURE?
    By Oakville in forum Legalese
    Last Post: 09-09-2011, 11:45 AM
  2. passenger door lock stopped working
    By BongRips in forum GTS Tech
    Last Post: 08-01-2011, 10:10 AM
  3. Speedometer and odometer stopped
    By Tairance in forum GTS Tech
    Last Post: 07-10-2011, 08:19 PM
  4. Driver side wiper stopped working :(
    By aN4rk1 in forum General Skyline Discussion
    Last Post: 09-13-2010, 08:37 PM
  5. power window stopped working
    By GT-Rob in forum GTS Tech
    Last Post: 03-29-2006, 11:29 AM
