Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Coil packs
    Jan 2009
    Vancouver
    19
    Coil packs
    So what is a preferred brand of coil packs for a rb25det? My R33 just started to have some popping and hesitation at 5000-6000 rpm range.
    Jun 2011
    Toronto
    1,562
    I know lots of guys with big hp/trq numbers go with Splitfire.
    NGK 1.1mm spaced rings a bell.
    I wonder what 300ZX OEM ones are good for...
    Because race car.
    GTRCer nimblestix's Avatar
    Mar 2007
    Maple Ridge
    502
    yellow jackets are fine. just got a set and they work just as well as the splits i had in the day before.
    edit: oh yeah and they're about $415 shipped to your door (lower mainland) within 5-7 days
    Jun 2011
    Toronto
    1,562
    Quote Originally Posted by nimblestix View Post
    Do you know what the gap spec for the YJ's are?
    Because race car.
    Jan 2009
    Vancouver
    19
    WHat about spark plugs and gap?
    GTRCer danwit's Avatar
    Sep 2009
    hamilton
    239
    Quote Originally Posted by some_punk View Post
    the plugs are BCPR6EIX gapped 1.1mm if your running stock boost. Spark starts to effect boost around 12psi. Anything more you want to gap them .8mm should go a heat range colder also.
    I canz take this corner at 195k cause i gots AWDZ. Get real.
    Jan 2009
    Vancouver
    19
    is that BCPR6EIX11 or just BCPR6EIX?
    Sep 2009
    hamilton
    239
    Well 11 is the gap.. Being 1.1mm
    GTRCer BongRips's Avatar
    Mar 2011
    the 204
    299
    if you get the bcpr6eix they are pregapped to .8mm. As far as I remember, NGK plugs with -11 on the end are gapped to 1.1mm and a plugs with the same product id number or w/e except it doesn't have the -11 it will be gapped to .8mm
    Banned
    Oct 2010
    Mallorytown,Ontario
    1,024
    I run BKR7E in mine and they work awesome! +1 for yellow jackets!
  1. FS: USED OEM R32/R33 Coil Packs set
    By pmdawg in forum Parts for Sale
    Last Post: 07-06-2011, 02:29 PM
  2. Coil Packs going?
    By Joker in forum GT-R Tech
    Last Post: 05-02-2008, 09:14 AM
  3. Coil Packs
    By RedDragonKnight in forum GT-R Tech
    Last Post: 09-25-2007, 10:41 AM
  4. FS: Used Coil packs (x6)
    By Truman in forum Parts for Sale
    Last Post: 02-05-2007, 01:05 AM
  5. Replies: 2
    Last Post: 12-07-2006, 11:27 AM
