Results 1 to 5 of 5
Thread: HELP needed: need new injectors questions!
    Oct 2011
    Port Coquitlam
    7
    I Just got my skyline (1990 gts-t) and my mechanic told me i need new injectors which i had a hunch on considering the smell of gas absolutely everywhere. The injectors have been upgraded to 444cc gtr injectors before.
    I assume the resistors have been done now since the 444's worked.
    am i able to drop in any injector now? 444cc -550cc? without changing the resistors?
    and where do you buy them in the lower mainland. i don't want to wait for shipping as i shouldn't be even driving the car its so bad.
    I would prefer brand new ones. is there a nismo 444cc part number that can be ordered from nissan?
    someone on the site is selling JECS 550cc side mount injectors. will they fit?
    JECS 550 Side mount Fuel Injectors
    I don't know much about the mechanical portion of the car yet since i just got it and want to get it fixed properly before i start learning on it.
    The car is a 1990 gts-t with splitfire coils, intercooler, r34 turbo, walbro 255lph pump, aluminum rad... etc
    any help would be greatly appreciated as this is my daily driver
    Thanks guys
    GTRCer Zacho's Avatar
    Jul 2008
    Edmonton
    535
    The injectors you can swap in depends on your fuel rail type (side feed/top feed) and injector impedance. You can't just drop in anything now that the resistors have been added. If you want to not change the resistors, use injectors with the same impedance your current ones have.
    The ones linked will not work. Your rb20 rail is top feed and those are side feed injectors.
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Some run Deatschwerks injectors.
    Deatschwerks GTR injectors (need ECU retune) -
    http://www.deatschwerks.com/products...rb26dett-89-02
    RB20DET injectors (buy another stock RB20DET injector loom, need ECU retune) -
    http://www.deatschwerks.com/products...-rb20det-89-94
    Oct 2011
    Port Coquitlam
    7
    so the cheapest way would be just finding some 444 gtr injectors and swapping them in i assume.
    anyone know of somewhere that can order them new? or have a nissan part number?
    thanks for the quick replies!
    Sep 2007
    South
    6,702
    Yes, cheaper option.
    I think they are Denso brand injectors. Part number should be on the injector.
    Denso has a office in Canada -
    http://www.globaldenso.com/en/aboutd...ndex.html#DSCN
    Stock fuel parts on NISSAN's are either JECS or Denso.
  1. RB25 Injectors, rail and FPR questions
    By RHDskyline in forum General Skyline Tech
    Last Post: 11-04-2010, 10:20 AM
  2. Replies: 6
    Last Post: 10-21-2010, 11:21 AM
  3. HELP needed to find injectors and spark plugs
    By cwestskylinegtr in forum Want to Buy
    Last Post: 03-01-2007, 09:18 AM
  4. HELP needed to find injectors and spark plugs
    By cwestskylinegtr in forum General Skyline Discussion
    Last Post: 02-27-2007, 12:22 AM
  5. Replies: 2
    Last Post: 08-02-2006, 08:12 PM
