Results 1 to 4 of 4
Thread: Fuel Injector Leak
    GTRCer Madskyline's Avatar
    Jun 2010
    Etobicoke
    71
    Fuel Injector Leak
    hey guys,
    so i started smelling gas in the car so i pulled over and poped the bonet and started looking for signs of fuel leaks and quickly found one at injector 1. now i did some research and found that that injectors have a o ring at the top(fuel rail) and a insulator on the bottom. please correct me if thats worng. now the leak was on the bottom of the injector and i could lightly twist it and the idle changed and the amount of fuel slowed. does this mean that my insulator is gone? thanks for reading and sorry for the basic question.
    Banned
    Nov 2011
    TO
    87
    well if its an external leak I could see an o-ring being to blame. check the injector o-rings to make sure they're seating properly , if not call Nissan or go to like Princess auto and pick up some O-rings.
    Jun 2010
    Etobicoke
    71
    the yellow ring is where the injector is leaking from and from what i found in pictures there is no oring at that part.....just wanted to get some info on this befor taking it apart. is the insulator the bottom o ring or the thing that makes the seal
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,055
    if your 100% sure thats where its coming from, then u have an injector thats crapped out on you. i was fighting leaky fuel injectors for the longest time and finally found out that it was the rising rate FPR that the previous owner had installed. so make sure thats not the case.
    A. Nash
  1. Fuel leak?
    By DrewB in forum GTS Tech
    Last Post: 06-22-2008, 05:27 PM
  2. fuel leak
    By RBforlife in forum GTS Discussion
    Last Post: 12-08-2007, 07:49 PM
  3. Fuel system leak #3!
    By Bruizer in forum GT-R Tech
    Last Post: 11-09-2007, 12:52 AM
  4. Serious fuel leak!!!
    By SxyBeast in forum GT-R Tech
    Last Post: 10-25-2007, 08:16 PM
  5. fuel injector?
    By Irfan.a.f.g. in forum GT-R Tech
    Last Post: 06-15-2007, 07:49 PM
