So I recently replaced my brake master with one from a 91 Pathfinder. Main difference is the r32 has 2 ports for front and rear brakes. The pathfinder has 3. Both front calipers are independent. All I did was buy two 3/16"X8" premade brake lines and a 3/16" brake line tee. Basically take both lines from the front ports and tee them together, then take your existing line and run that into the tee. Done! Bleed it out and it works perfectly. Abs functions normally and braking power is dramatically improved as the pathfinder bmc has a 1" bore.
You will have to rebend the existing line to mate up with the new tee, just be careful not to kink the line.
LinkBack URL
About LinkBacks
