Does anyone one know how long in labour it would be approximately to replace my subframe bushings?
How much time the job will or should take. Need an idea so I can plan my spring upgrades
Thanks
Thanks
R33 GTST RB25DET series 1
When I did mine. I put in solid aluminum AMS subframe bushings it took me in my garage approximately 8 hours of full work spred over 3 days. I have a gts-4 so it took longer because of attessa system and having to re bleed everything. But not having a press sucked and having to burn out the old rubber and hammer out casing. If you have gtr or gts-4 and are doing should aluminum subframe bushings you are gonna need another spacer approx 1.5-2 inch think because AMs said there is no difference but there is and you run out of thread when tightening bolts .... Hints the extra spacer.
Thanks for the info
8 hours.....wow!
I'm going to do an energy suspension polyurethane bushings
Don't want to go solid as I drive it 20,000 km a year.
I have a gtst so I don't have to worry about the atessa
3-4 hours? I assume my shop has all the proper tools needed
If you have a hoist and press definitely. Longest part was getting old bushings out.
Ps I have solid aluminum and drive 25,000 km every year.
I am here: http://tapatalk.com/map.php?fjrvcm
