So I am planning on a rb25 swap this spring and was wondering if the ecu pin-outs need to be changed for injector 4 and 6. I know that that's the only difference between the wiring of the rb20 and 25 (except for the variable timing) because with the Haltech Platinum Pro, it can be used on all r32/33s but for the rb20det and rb25de you need to swap pins 112 and 114. Would I need to swap them after doing the engine swap or leave them the same?![]()
LinkBack URL
About LinkBacks
because im using the rb20 ignitor and coil pack loom on my rb25 as the rb25 ign and loom dont fit the rb20 harness
