Results 1 to 4 of 4
Thread: another clutch thread
    GTRCer Evans's Avatar
    Apr 2011
    Summerland, BC
    59
    i understand all vg30de (z32) clutches will fit in the HNR32. is that the same for the other components in the bell housing? ie. pressure plate, flywheel, release bearing, and all that stuff?
    GTRCer BrianV8's Avatar
    Aug 2008
    Kamloops
    2,051
    If i remember correctly
    Bell housing does not work
    If looking at aftermarket clutches pressure plate and disc are the same
    flywheel i "think" is the same not positive
    Best bet is just use google and compare part numbers, there are lots of cross over threads even on this forum should be mentioned
    GTRCer Tony-R32's Avatar
    Sep 2010
    Winnipeg
    1,063
    Clutch disk, pressure plate, pilot bearing, release bearing will all fit no problem.
    I don't know 100% on the aftermarket flywheel fitment though, I would assume as the vg30de after market flywheel was good for the HCR32, it would also be good for the HNR32.
    GTRCer mightyrocker's Avatar
    Oct 2007
    Calgary, AB
    1,404
    everything but flywheel.... flywheel is 8 bolt
    Moarr Pawarr
    Quote Originally Posted by m_melen View Post
    OMGZORZ I LOVE SKYLINES!!!!!! BWAAAAAAHHHHHHH!!!!!
  1. WTB WARPED/Worn/Skipping OS Giken Clutch or clutch plates
    By tryingtobebest in forum Want to Buy
    Last Post: 02-10-2012, 12:24 AM
  2. Replies: 16
    Last Post: 08-14-2011, 03:24 PM
  3. Replies: 3
    Last Post: 02-16-2011, 12:09 AM
  4. wtb: clutch and clutch release bearing
    By maxgohan in forum Want to Buy
    Last Post: 10-12-2007, 06:45 PM
  5. Replies: 18
    Last Post: 04-24-2007, 06:58 AM
