Results 1 to 3 of 3
Thread: Won't start
    Nov 2010
    Waterford
    248
    Won't start
    So I have an rb25 series 2 in my 240sx
    I removed every single wire that came stock on the car and am trying to get the car running by running powers and such to the needed wires on the ecu.
    The car wants to fire on initial start up but then doesn't.
    I am getting spark and fuel just it won't actually run.
    Can anyone give me ideas to what would cause this?
    Need the car for Saturday,
    Thanx in advance, Brad
    GTRCer Skym's Avatar
    Sep 2007
    South
    7,968
    Check CAS, ignition module wiring. On series 2 RB25DET the ignitors are installed into each coilpack, so each coilpack can be turned off via ECU when cheking for a failed coilpack.
    If CAS is stuffed the engine gets harder to start when cold or hot. If CAS is unplugged the engine won't start (usually CAS is unplugged when priming a new turbo with oil before starting engine). Ignition module does something similar, but takes 10 minutes of driving (to heat ignition module up) before engine stalls and won't start until ignition module cools down.
    Also check wiring to fuelpump, fuelpump.
    Nov 2010
    Waterford
    248
    Found out the issue, the maf is not grounding properly
  1. Won't start help!!!
    By wannabe_sky in forum GT-R Tech
    Last Post: 01-31-2012, 01:30 AM
  2. car won't start...
    By andrewr32 in forum GTS Tech
    Last Post: 05-06-2007, 08:53 PM
  3. car won't start
    By skyline_GTS-T_type_M in forum GTS Tech
    Last Post: 04-05-2007, 05:39 PM
  4. GTR No start
    By Touring240 in forum GT-R Tech
    Last Post: 03-22-2007, 12:07 AM
  5. GTR won't start
    By uneak in forum GT-R Tech
    Last Post: 01-09-2007, 01:30 PM
