Results 1 to 4 of 4
Thread: RB parts
    GTRCer Modb's Avatar
    Feb 2012
    Dartmouth NS
    231
    RB parts
    So here is a list of EVERY part number for EVERYTHING from an RB/Skyline. Also lists parts that are interchangeable with USDM parts.
    Credit goes to HybridZ.org as that is where this is from.
    Part numbers for RB26DETT only, unless otherwise noted.
    Ignitor pack- R32/33- 22020-05U00
    Clutch Pull to push conversion-
    Late Model R32, R33 and R34’s
    Front cover assembly :32110-05U11 (japan part only)
    Gasket :32112-05U12
    Clutch fork :30531-01S00 (same part for a 1991-1993 240SX)
    Spring :30514-14600
    Spring :30534-E9000
    T/O bearing :30502-14601
    Bearing sleeve:30501-S0160 / 30501-N1601 (14mm for twin / trip disc)
    Bearing sleeve: 30501-K0404 (24mm for single disc)
    Dust cover :30542-31610
    Slave cylinder :30620-21U01
    Flywheel bolt: 12315-04U00
    Factory Clutch
    R32 GTR
    Disc- C0100-05U15
    Cover-30210 - 05U01
    Bearing- 30502-21000
    R33 GTS
    Disc- 30100-21U01
    Cover- 30210-21U00
    Throw out bearing- 30502-12U00 (300ZX part) or 30502-45P00 (300ZX part)
    Bearing Sleeve- 30501-S0200 (18mm)
    R33 GTR
    Disc- 30100-0V708
    Cover- 30210-24U00
    Bearing- 30502-12U00
    R34 GTR
    Disc- 30100-0V708
    Cover-30210 - AA300
    R32/33 Brembo Brake pads-
    F 41060-12U87
    R 44060-12U87
    Belts-
    RB26 R32 4 Ribs
    AC- 925 mm
    Power Steering- 950 mm
    Fan- 880 mm
    RB26 R33/R34- 4 Ribs
    AC- 910 mm
    Power Steering- 969 mm
    Fan- 875 mm
    R32- RB25
    AC- 4 ribs 925mm
    PS- 3 ribs 845mm
    Fan- 4 ribs 860mm
    R32- RB20
    AC- 4 ribs 925mm
    PS- 3 ribs 855mm
    Fan- 4 ribs 860mm
    R33- RB25
    AC- 4 ribs 910mm
    PS- 3 ribs 845mm
    Fan- 4 ribs 850mm
    R33-RB20
    AC- 3 ribs 910mm
    PS- 3 ribs 855 mm
    Fan- 4 ribs 850mm
    R34- RB25/RB20 - 4 Ribs
    AC- 910mm
    PS- 865mm
    Fan- 890mm
    Water Pump-21010-58S25
    N1 Water Pump- 21010-21U26
    N1 oil pump- 15010-24U01
    R32 Thermostat - 21200-42L06
    R32 ABS Unit- 47600-05U00
    R33 ABS Unit- 47600-15U00
    R32 Power steering pump- 49110-05U00
    Intake gasket- 16175-05U70 (3 needed)
    Nismo AFM’s 22680-RR580
    Standard AFM’s 22680-05U00
    Lower rad hose- 21603-72L00
    Upper rad hose- 21501-05U00
    R32 ATTESA valve- 49836-01U00
    R33 AC Compressor- 92600-24U15
    R32 Clutch master Cylinder- 30605-05U00
    R32/33 CAS 23731-02U10/1
    R32 Starter- 23300-20P00
    N1 Block- 11000-24U00
    Injector O-Rings- 16635-78A00
    Valve cover gasket- 13270-58S11 and 13270-58S01
    Valve cover half moon seal- 11051-58S00
    R32 AAC- 23781-05U11
    R32 GTR ECU- Hitachi- 23710-05U02/01
    R32/R33 Twin Cam valve cover strip- 13290-05U00
    R33 Front Hood Spoiler-65834-24U00
    R32 Oil Pressure Sender- 25070-30P01
    R33 AC Hoses
    Flexible low pipe - 92480-98U00
    Front cooler high line- 92440-24U20
    Flexible low hose- 92490-24U10
    R33 Heater core compatible with Z32 heater for you must reuse your plastic inlet and out lines- TBA
    RB26 Dip Stick- 11140-05U02
    R32/33 Starter- 23300-20P05
    R32 Alternator (Mitsu unit) 23100-20P10 (90 amps) 23100-86L11 Mitsu (90 amps) and 23100-86L12 Mitsu
    R33 Alternator 23100-70T13 Mitsu (80 amps) 23100-70T03 hitachi (80 amps) 2/97~up 23100-0V010 Mitsu (80 amps)
    R34 Alternator 23100-0V016
    R32 2WD model Alternators
    23100-59S01, 23100-85L00 Hitachi
    23100-85L10, 23100-85L11, 23100-85L11 Mitsu
    Found this on GTR UK
    BNR32
    Part Number Item Description Common To Other Source Notes
    13028-20P25- Belt - Timing no
    16400-72L00- Strainer Assy - Fuel U13
    21200-42L05- Thermostat Assy Y32
    22401-58S15- Plug - Spark KN13 w/CA18DE
    28890-01U00- Blade Assy - Windshield no
    28890-51S10- Blade Assy - Windshield B13
    28790-56E00- Blade Assy - Rear Window U12?
    30100-04U00- Disc Assy - Clutch no
    30210-73L00- Cover Assy - Clutch no
    30502-21000- Bearing - Clutch Release Z31 turbo
    46210-04U00- Hose Assy - Brake, Front no
    46214-01A11- Hose Assy - Brake, Rear B13
    37521-01U26- Bearing Kit - Center (Driveshaft) no from 89/11 to 90/08
    38300-84M79- Final Drive Assy no without EAL sensor
    39241-73L25- Repair Kit - Seal, Outer (outer CV boot, rear) Z32 non-turbo
    39741-03P27- Repair Kit - Seal, Inner (inner CV boot, rear) Z32 non-turbo
    30611-71L25- Piston Kit - Clutch Master Cylinder WD21 '90-'91
    30621-26E25- Piston Kit - Clutch Operating Cylinder no
    32114-Y4000- Seal - Oil, Front Cover (Transmission) D22 '00+ KA24DE
    32112-04U00- Gasket - Front Cover (Transmission) S13?
    32136-U0100- Seal - Oil, Rear Extension (Transmission) D22 '00+ KA24DE
    32870-V5003- Socket Assy - Control Lever (shifter bushing) S13
    32862-V5001- Boot - Control Lever (inner shift boot) S12
    38342-P9000- Seal - Oil, Differential Side Z32 non-turbo
    38440-N3100- Bearing - Differential Side WD21 '90-'93
    38189-21G00- Seal - Oil, Drive Pinion WD21 '88-'90
    38120-13210- Bearing, Drive Pinion, Front Z32 non-turbo
    38120-10V00- Bearing, Drive Pinion, Rear Z32 non-turbo
    39711-73L00- Joint Assy - Inner (rear CV joint) Y32
    43210-AA000- Bearing - Rear Axle, Inner no
    43206-01U00- Rotor - Disc Brake, Rear Z32 '90
    40210-33P02- Bearing Assy - Front Wheel Z32
    40206-04U00- Rotor - Disc Brake, Front no
    54524-01U67- Link Complete - Front Suspension, Upper RH no 54524N
    54524-01U67- Link Complete - Front Suspension, Upper LH no
    54500-01U01- Link Complete - Transverse, RH no 54500
    54501-01U01- Link Complete - Transverse, LH no
    54590-01U25- Extension Complete - Knuckle Arm, RH no 54590
    54591-01U25- Extension Complete - Knuckle Arm, LH no
    56112-A0100- Bush P11 56112
    54618-56S11- Rod Assy - Connecting, Stabilizer S14
    56112-V0100- Bush P11 56112+A
    54468-01U00- Rod Complete - Tension, Front Suspension no
    54476-35F20- Bush - Mounting, Tension Rod G50
    54613-01U11- Bush - Stabilizer no
    54050-01U11- Bumper Assy - Bound no
    43252-30P00- Seal - Grease, Rear Hub Z32 non-turbo
    55157-33P00- Bush Z32 43052E
    55152-35F00- Bush G50 43052D
    56219-33P00- Bush Z32 43052F
    55130-32P00- Link Complete - Upper, Rear Suspension Rear Z32 8903 - 9008 55130M
    55120-71L00- Link Complete - Upper, Rear Suspension Z32 8903 - 9006 55120
    56113-33P00- Washer - Rear Stabilizer S13 56113M
    54612-35F00- Bush - Rear Stabilizer Z32 56243+A
    54612-01P00- Bush - Rear Stabilizer Z32 56243
    55501-35F00- Arm Assy - Rear Suspension, RH Z32 non-turbo to 9006 55501
    55502-35F00- Arm Assy - Rear Suspension, LH Z32 non-turbo to 9006 55502
    54613-71L10- Bush - Rear Stabilizer S13 56243+B
    55490-01U00- Damper Assy - Dynamic, Rear Suspension no
    55475-35F00- Stopper - Member Mounting Lower S13 55475M
    56217-71L00- Bush - Rear Shock Absorber P11
    55154-30P00- Ball Joint Assy - Rear Axle Z32 turbo
    55114-39F10- Link - Lower, Rear Suspension S13 55114+A
    55114-39F00- Link - Lower, Rear Suspension S13 55114
    48203-39F25- Boot Kit - HICAS Actuator S13
    36530-71L00- Cable Assy - Brake, Rear Right no
    36531-71L00- Cable Assy - Brake, Rear Left no
    46011-30P25- Piston Kit - Tandem Brake Master Cylinder no same as GT-R
    46010-04U20- Cylinder Assy - Brake Master no Three different brake master cylinders listed - check first
    Started rebuilding my skyline when i was 18
    1992 GTST RB25DET
    http://forums.gtrcanada.com/gts-project-cars/54849-saved-my-car-great-scrap-heap-sky-redo-my-first-car-thread.html
    Quote Originally Posted by Bravo View Post
    PS My wife just told me I was shitting in your Cheerios!
    I'm sorry,
    Good luck!
    Feb 2012
    Dartmouth NS
    231
    48080-50M11- Joint Assy - Steering, Lower KN13
    49110-04U00- Pump Assy - Power Steering no
    49200-04U00- Gear Assy - Power Steering (steering rack) no
    49271-04U00- Rack Assy - Power Steering no
    48521-72E00- Socket Assy - Tie Rod, Inner P10
    48520-71L25- Socket Kit - Tie Rod, Outer no
    49365-10V26- Seal Kit - Oil, Rear Housing (of steering rack) B14
    49277-42L00- Seal Set - Piston Z32 '90-'92
    49297-10V25- Seal Kit - Housing, Power Steering Gear U12?
    48203-10V25- Boot Kit - Power Steering Z32
    22433-60U01- Coil Assy - Ignition G50 '91 does not include protector
    22020-05U00- Transistor Ignition Unit no same as GT-R
    23731-79S10- Camshaft Position Sensor no two listed, check first
    25080-89903- Sensor - Temperature Z32 25080X
    25070-55S60- Sensor - Oil Pressure Z32 '90
    25085-89900- Sensor - Boost Z32
    23100-59S01- Alternator Assy no
    23300-20P00- Motor Assy - Starter no
    23343-20P00- Switch Assy - Magnetic (starter solenoid) B14 '94 GA16DE MT
    25567-71L01- Body - Combination Switch no
    25570-71L00- Switch Assy - Mirror Control no
    24345-51E60- Cover - Connector (for battery connector) P10
    24080-01U00- Cable Assy - Battery Earth no
    24077-01U00- Harness Assy - Engine no
    24022-F6100- Wire Assy - Fusible Link F31 24022
    24022-55S60- Wire Assy - Fusible Link no 24022+A
    24010-01U13- Harness Assy - Main no
    25560-02U00- Switch Assy - Combination no
    25260-01U00- Switch Assy - Wiper no 25260P
    25260-01U10- Switch Assy - Wiper no 25260PA
    25290-01U00- Switch Assy - Hazard no
    25160-01U00- Switch Assy - Lighting no
    25350-01U00- Switch Assy - Rear Defogger no
    25540-01U22- Switch Assy - Turn Signal no
    25450-01U10- Switch - Sunroof no
    25401-04U00- Switch Assy - Power Window, Main no
    25431-01U00- Switch Assy - Power Window, Assist no
    28515-01U00- Amplifier Assy - Auto Power Window no
    28511-01U01- Amplifier Assy - Windshield Wiper no
    28475-01U00- Sensor Assy - Steering no
    26025-01U00- Housing Assy - Head Lamp, RH no three kinds listed, check first
    26075-01U00- Housing Assy - Head Lamp, LH no
    26719-C9946- Bulb (headlight) G50 '91-'93 26011AD
    26124-01U00- Body Assy - Combination Lamp, RH (front) no
    26129-01U00- Body Assy - Combination Lamp, LH (front) no
    B6554-04U00- Body Assy - Combination Lamp, RH (rear) no
    B6559-04U00- Body Assy - Combination Lamp, LH (rear) no
    26552-04U04- Rim - Combination Lamp, RH (rear) no
    26557-04U04- Rim - Combination Lamp, LH (rear) no
    28930-01U00- Nozzle Assy - Washer, No. 1 (driver's side) no
    28931-01U00- Nozzle Assy - Washer, No. 2 no
    28970-01U00- Nozzle Assy - Rear Window Washer no
    28920-71L10- Pump Assy - Washer no
    27140-71L10- Core Assy - Front Heater U12
    27220-91L00- Motor & Fan Assy - Blower P10
    21410-04U00- Radiator Assy no
    21501-04U00- Hose - Radiator, Upper no
    21503-72L00- Hose - Radiator, Lower no
    21430-01F01- Cap Assy - Radiator B13
    48470-04U00- Cover Set - Steering Column no
    G2716-89901- Dam Rubber - Sealant S13
    72750-04U10- Moulding Set - Windshield no
    72712-05U05- Glass - Windshield no
    72725-04U10- Fastener - Moulding no
    G2716-89902- Dam Rubber - Sealant (rear window) D21
    79780-04U10- Fastener - Moulding no
    79712-04U17- Glass - Rear Window no
    79750-04U10- Moulding - Rear Window no
    80730-F6100- Motor Assy - Regulator, RH S13
    80731-F6100- Motor Assy - Regulator, LH S13
    80720-04U00- Regulator Assy - Door Window, LH no
    80721-04U00- Regulator Assy - Door Window, LH no
    80300-04U00- Glass Assy - Door Window, RH no
    80301-04U00- Glass Assy - Door Window, LH no
    83306-04U10- Glass Assy - Side Window, RH no
    83307-04U10- Glass Assy - Side Window, LH no
    96365-35F00- Glass - Mirror, RH Z32
    96366-35F00- Glass - Mirror, LH Z32
    96321-01U00- Mirror Assy - Inside no
    10101-73L25- Gasket Kit - Engine Repair no
    11042-72L25- Gasket Kit - Valve Regrind no
    12279-42L00- Seal - Oil, Crankshaft Rear no
    11121-42L00- Gasket - Oil Pan no
    11044-58S01- Gasket - Cylinder Head no
    13270-58S01- Gasket - Rocker Cover no
    13270-58S11- Gasket - Rocker Cover no
    15255-40F00- Cap Assy - Oil Filler B13 w/GA16DE
    11220-02U02- Insulator - Engine Mount, Front no 89-'91
    11320-41L03- Insulator - Engine Mount, Rear no
    13231-58S12- Lifter - Valve no same as twin-cam CA engines
    13070-73L00- Tensioner Assy - Belt (timing belt) no
    14035-72L10- Gasket - Manifold (intake manifold to head) no
    14032-72L00- Gasket - Intake Manifold (intermediate) no
    14036-58S00- Gasket - Exhaust Manifold no
    14415-V5300- Turbocharger Inlet Gasket Z31 turbo
    14445-V2700- Turbocharger Outlet Gasket no
    14465-26E00- Gasket - Inlet Tube (turbo compressor) Z32 turbo 8907-8912
    15196-P7600- Turbocharger Oil Outlet Gasket Z31 turbo
    14401-72L26- Turbocharger Gasket Kit no
    15010-79S05- Pump Assy - Oil no
    13510-19V00- Seal - Oil, Crankshaft Front no
    22620-02U00- Throttle Position Switch no
    16175-79S00- Gasket - Throttle Chamber no
    22670-72L02- Regulator Assy - Pressure (fuel pressure) no
    25060-01U00- Sender Unit - Fuel Gauge no
    21010-42L25- Pump Assy - Water no
    17042-73L02- Pump Assy - Fuel no
    17251-79915- Cap Assy - Filler B12
    BCNR33 Suspension part numbers
    54618-05U00- front anti-roll bar link (goes on the end of the roll bar)
    40160-AR510 front inner ball joint
    40160-05U00 front outer ball joint
    54613-01U11 front anti-roll bar bush
    54614-05U00 front anti-roll bar bracket
    R32/33/34
    Wheel bearings
    40210-05U00- Front
    43280-AA3001- rear
    43281-AA3001- rear
    Hub seals
    40232-33P55- front
    43252-40P00- rear
    R34 CAS- 23731-5L300
    Updated 3rd, 4th and 5th gear trans part (R32-R33)
    32606-30P10 Coupling sleave
    32251-30P14 2nd gear
    32604-30P60 ring 5th
    32261-12014 3rd gear
    32604-30P61 ring
    32811-05U10 shift fork
    32611-AA510 Coupling sleave
    32609-70L15 Shifting insulator X3
    32201-05U71 Main drive gear
    32604-40P61 ring
    32605-30P11 Hub
    32603-30P00 Spring shifting X2
    32212-AA504 Counter gear
    32230-054U24 First gear
    32137-AA500 Plate
    32341-30P04 Over drive gear ( 5th gear )
    32245-30P60 Reverse gear
    32220-30P60 Reverse gear
    32614-30P60 Ring
    32615-30P60 Shifting insulator X3
    32214-01G21 Corn counter
    32616-30P20 Coupling sleave
    32282-30P61 Reverse gear
    32320-VB361 Shaft
    32139-VB300 retainer
    32312-30P24 gear
    32320-VB361 shaft
    just got off the phone with 2 nissan dealers, they said that:
    (Throw out bearing) 30502-21U00 was not a good part #
    They said that Clutch Bearing- 30502-45P00 ($33) was a good # and they called this one the throw out bearing???
    also, P/N 30501-S0200 has been replaced with P/N 30501-S0284 ($26)
    They gave me part # 32202-B9500 for a pilot bearing??
    Could somebody with more knowledge than me clear this up? Thanks!
    F/A info:
    R33 GTS
    Disc- 30100-21U01
    Cover- 30210-21U00
    Throw out bearing- 30502-21U00 (300ZX part)
    Clutch Bearing- 30502-45P00 (300ZX part)
    1992 GTST RB25DET
    I'm sorry,
    Good luck!
    Dec 2008
    GTA
    802
    Wow, that's a lot of stuff
    I'll just ask as I can't see on the iphone.
    I need: r33 drivers side power windows/lock control and battery terminal cover
    Pm please thx
    R33 GTST RB25DET series 1
    GTRCer Kunzz's Avatar
    Nov 2010
    Toronto, Ontario
    432
    Quote Originally Posted by r33_gtst View Post
    Pm please thx
    Don't hold me to it but this seems close from what i can see
  1. full rb20det part out, some rb25 parts. some RB into s13 parts.
    By littlenicky24 in forum Parts for Sale
    Last Post: 12-28-2011, 08:16 PM
  2. BNIB rb26 aftermarket parts.Engine parts ACL,ARP,Weisco, BC
    By Mitsuboost30 in forum Parts for Sale
    Last Post: 02-10-2011, 02:41 AM
  3. Replies: 2
    Last Post: 01-01-2011, 07:56 PM
  4. 1992 GTR parts for sale or trade. various parts.....
    By playtime in forum Parts for Sale
    Last Post: 11-14-2010, 09:35 PM
  5. FS: Greddy BNCR33 Parts From USA and stock parts
    By engiNERD in forum Parts for Sale
    Last Post: 04-09-2008, 11:16 PM
