Hi guys,
Here is a list of products we offer from Powerhouse Racing for the R32 and R33 Skylines. If your interested in getting something custom made please feel free to contact me and I can get everything lined up for you!
Race Breather Kit for RB26DETT
Powerhouse Racing offering a Race Breather Kit, one of a kind! Internal baffling that can hold up to 3 quarts in fluid, Ventilation and even a drain plug at the bottom. One feature for the Skyline that can be added on is a drain line at the bottom to go back into the oil pan but this is not included. These use -12AN lines and comes with a show room finish. R32 you will have to relocate the Battery and R33 / R34 will have to relocate the Windshield Washer Fluid Reservoir.
MSRP: $750.00 USD
GTRCanada Price: $499.00 USD
5" Intake Aluminum Pipe Kit with couplers and clamps.
Powerhouse Racing releasing the newest, biggest and baddest thing on the market to allow those monstor Turbochargers that Time has brought and seems that every customer now has one. These are one mint piece and with a show room finish you wont want to use it. These come with Blue, Red or Black Silicone and a K&N 5" Cone Filter.
MSRP: $225.00 USD
GTRCanada Price: $185.00 USD
Billet Radiator Support Brackets
Powerhouse is proud to release the new pair of Radiator Support brackets that are thicker, stonger, stylish and fully polished! These brackets are made out of 6061 Aluminum to finish out a nice shine in the engine bay! This is a BRAND NEW PRODUCT that just hit the market!
Note - These use the factory Rubber Bushings.
MSRP: $90.00 USD
GTRCanada Price: $75.00 USD
Billet Optima Battery Bracket Tray
Truly a work of CNC art! This billet aluminum battery tie down kit is specifically designed for the Optima series of dry-cell batteries. Beautifully finished in brushed aluminum with concealed fasteners. All hardware is included for a complete installation.
MSRP: $175.00 USD
GTRCanada Price: $135.00 USD
Billet Nitrious Bottle Bracket
This is the most well-designed NOS bottle bracket on the market, hands down! Designed to fit any standard NOS or NX 10lb nitrous bottle, with angle adjustment for best positioning in the vehicle. Features a small mounting base, designed to fit in tight spaces where most normal bottle brackets won't fit! And the best part is, you don't have to remove the bottle from the bracket every time you want to re-fill the bottle! Simply remove the two quick-release mounting pins and the bottle harness removes from the mounting base easily! The bracket even converts into a bottle carrier to make hauling around the NOS bottle easier. It doesn't get any better than this folks
MSRP: $250.00 USD
GTRCanada price: $189.00 USD
Coilpack Cover for RB25DET
Powerhouse Racing, offering a sleak and stylish Coil Pack Cover that functions to the Skyline needs. This Coil Pack Cover can come polished or unpolished and is vented for the functional purposes of coil packs overheating.
MSRP: $299.00 USD
GTRCanada price: $249.00 USD
Dress Up Bolt set for RB26
Take pride in your engine bay or engine? Its time to take it to the next level with a Titanium dress up kit for your engine bay and engine! These kits are a complete replacement for most visible bolts and nuts on your specific vehicles engine bay, ready to bolt in as soon as they arrive.
Our Titanium kits utilize the highest grade titanium while retaining an exceptionally high tensile strength. Our bolts have been tested to be stronger than Grade 8 Stainless Steel bolts, all while maintaining a beautiful anodized finish that will set your car above and beyond the rest in terms of attention to detail.
GTRCanada price: $43.99 USD
Fuel System
This has EVERYTHING and I do mean EVERYTHING from the back of the car starting with the filters, pumps, Insulating Pump Wrap, washers, fittings, In-tank hose, clamps, Fuel Hat, -8AN Feed Line, Filter, Y Block, Fuel Rail, Injectors, Adapters, Injector Clips, Fuel Rail, Brackets, Fuel Pressure Regulator, Fuel Pressure Gauge, Custom Fittings, Fuel Pressure Gauge, -6AN Return Line.
This is ONE COMPLETE KIT!!!!
Our fuel system uses stainless lines with a Teflon inner coating that will allow you to run E85 so that it wont allow moisture to enter the fuel line. We also have the Black anodized Rail and Weldon Fuel Pressure Regulator for an upgraded option.
Rails come in Polished or Black Anodized. You will need to specify if you have an RB25DET or RB26DETT because we have separate mounting hardware for both applications. Each fuel rail has the option to use an 11mm Injector or 14mm Injector based on preference. Fuel Hats have been tested and will not FIT R32 GTST and Not confirmed but claimed Not to fit R32 GTR. Hats Fit all R33, all R34, S13 and S14.
This can handle 1000hp with ease.
GTRCanada price: Please contact us with injector sizing any specifics you might want.
-8AN Fuel Rail Kit for RB25DET / RB26DETT
Comes in 11mm Denso or 14mm Domestic.
Powerhouse Racing has evolved around quality and perfection and with the new Skyline community we bring the High Flow Fuel Rail Kits that come in both Polished and Black Chrome. These rails are always in stock and have key features that leave other companies behind:
* Injector bosses which replace the rubber orings to but a tight fit on the o-ring on the injector.
* Black Chrome or Polished.
* 14mm Domestic Style Injector Size or 11mm Denso Style Injector Size.
* Mounting Brackets for either RB25DET or RB26DETT
NOTE - All Fuel Rail Kits come with a full install kit, nuts, bolts, orings, fittings and mounting brackets to make this a breeze of an install!
MSRP: $450.00 USD
GTRCanada price: $325.00 USD
CNC Ported Fully Built Race Head Kit for RB26
The technology is finally here! PHR is proud to offer the very first CNC ported cylinder head package for the RB26. This is the ultimate in cylinder head technology for the serious enthusiast and/or professional racer. We start with *brand new* Nissan cylinder heads, then let the 5 axis CNC machine perform its magic. The end result is hand blended and flow tested to over 300 cfm intake/200 cfm exhaust per valve at .450" lift. The benefit of CNC machining is that each cylinder is ported to the exact same profile, to prevent cylinder imbalances common to hand-ported cylinder heads. There is no core charge since we begin with brand new Nissan cylinder heads, this means you get the highest quality for your investment. This is for all-out race use only. Includes the full valvetrain upgrade, including 1mm oversize Valves, Dual Valve Springs, Titanium Retainers, Bronze Valve Guides, PHR Spec CNC Shimless Buckets and full 5 angle valve job.
These special CNC Ported Heads utilizing 1mm over Valves require Custom PHR Spec Boost Pistons and Special Coated Rings to allow proper clearance from the Oversized Valve. These Pistons allow better Flame flow in the cylinder and making up the compression loss from the CNC Head back to 8.5:1.
Also with the kit you have to purchase either 280 or 290 Lift Camshafts for the proper build and to allow us to check all clearances.
MSRP: $8690.00 USD
GTRCanada price: $7399.00 USD
* OEM Head purchased separately
CNC Intake Manifold for RB26DETT
This is truly something ground breaking for us and are pleased to show everyone this work of art. It has been flow tested to the RB26DETT Head (STOCK) and working on it flow tested to our CNC Head. These intake manifolds are not just a buy one and bolt it on. It is VERY SPECIFIC to your car.
When purchasing this intake manifold we need to know the ends and outs to everything going on with your setup on your motor.
Spec Sheet to be filled out:
* RPM Range
* Nitrous Single or Dual Rail
* TB Size
* Power Range Turbo size and flange
* Stock head or CNC head
* Stock Motor or Stroker Motor
* Fuel type and CC of Injectors
* Goals with the car ie: Drag racing, road racing, street etc.
This again is not just a bolt on, it will not only be specific to your car but make more HP and TORQUE to the ground because of our technology so singled out to your application. It is a one of a kind manifold and hands down will be proven to be the best. Equal / balanced velocity stacks and runners to YOUR spec! The first one is on its way to AU as we speak to get installed and dyno tested compared to STOCK and Hypertune to show the HUGH differences.
ETA on one of these manifolds?
Once the spec sheet is filled out and payment has been made these will take 1-2 weeks to be made then delivered to you.
Price?
* Price will start at $2900 RETAIL for the MANIFOLD only.
* Price on Rail $200
* Price on Throttle body $350-400 depending on size.
MSRP: $3200.00 USD
GTRCanada price: $2849.00 USD
We accept Credit Card, Interac Debit, Paypal, EMT, Wire Transfer, Certified Check, and cash in hand.
Regards,
Braden @ JNS Imports
LinkBack URL
About LinkBacks
