Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Engine Components
    GTRCer Braden @ JNS Imports's Avatar
    Jul 2006
    Lethbridge AB
    5,269
    Exclamation Engine Components
    Hi guys,
    Here is engine pricing, please refer to this when purchasing from us. We can get other brands but we usually recommend these and get them the quickest. If you would like another brand let me know and I can price!
    - Please contact me for stock checks
    - Prices subject to change without notice
    - Shipping is extra unless otherwise stated.
    - No GST on sale
    - Canadian price is an example price, to show rough cost. Proper exchange must be done!
    *** Only Skyline applications listed, for other applications please message me.
    Payment types accepted: Visa, Mastercard, Debit Interac, Email Money Transfer, Paypal, Wire Transfer, and Certified Check.
    - customer must pay all fees associated with the transaction.
    Bottom End:
    Oil & Water Pump
    Tomei Oversize Oil Pump
    - THEE best oil pump available for the RB engine
    - works on all RB motors
    Read what Tomei says: "The RB26DETT engine is often plagued with oil lubrication issues during circuit and drag racing events which are the main causes of most RB26 engine failures. This problem causes the main bearings to abnormally wear out from the lack of oil pressure. The stock pump is not capable of supplying the adequate amount of oil to maintain the right oil pressures at extreme engine speeds that the high powered monster RB26 performance engines require. Another weak point is that the stock pumps gear is made from weak sintered metal and this often breaks when going for bigger power and higher engine speeds and when this little piece gives out can cause an instant loss of your engine. The TOMEI RB26 oil pump has a larger pump gear made of high strength materials to supply a larger flow rate to the engine and it has an external oil pressure adjuster as well."
    P/N: 193035
    MSRP: $1840.00
    GTRC Price: $1564.00
    Nissan N1 Oil Pump
    GTRC Price: $245.00
    Nissan N1 Waterpump
    GTRC Price: $215.00
    Crankshaft:
    OEM R34 RB26 Crankshaft with larger crank collar
    P/N: 12200-05U03
    Price: $775.00
    Tomei 8-Counterweight Crankshaft
    P/N: 121025
    MSRP: $4640.00 USD
    GTRC Price: $4099.00
    Jdms13rhd Crank Collar
    GTRC price: $200 shipped anywhere in Canada
    -Made from 4140 High Tensile Steel
    -.001 Inch clearance each side
    -suited for .002 inch ID crush.
    -Full Drive
    -Fits OEM, N1 pumps perfectly!
    Harmonic Balancer:
    ATI 1000HP Super Race Damper
    - Eliminates torsional crankshaft vibrations
    - Exceeds SFI 18.1 specs
    - Laser engraved 360° timing marks
    - Black zinc chromate finished
    - P/N: 917752 (R32) & 917753 (R33/R34)
    MSRP: $650.00 USD
    GTRC Price: $499.00
    ATI 500HP Super Street Damper
    - P/N: 918599 (R32) & 918598 (R33/R34)
    MSRP: $575.00
    GTRC Price: $475.00
    Pistons:
    CP Forged Pistons:
    - Any size available
    - RB20 Pistons are considered custom, $100 more.
    - Dedicated forgings, Fully CNC machined Balanced to + or – 1 gram
    - Wrist pins provided at no cost, Pin fitting provided at no cost
    - Accumulator Grooves, Dual forced pin oilers, Pick lock grooves
    - USA Made
    MSRP: $900.00
    GTRC Price: $769.00
    Wiseco Forged Pistons
    - USA Made
    MSRP: $892.00
    GTRC Price: $749.00
    Tomei Cooling Channel Pistons & Titanium Coated Top Rings
    - "The ONLY forged pistons on the market that has the cooling channels like as in the OEM pistons. This is our best seller and almost always sold out whenever we get more stocks in. These are the best for endurance and drag racing events. Available in 3 sizes and can be used with our Titanium Coated Top Rings. Also can be used with the standard stroke or with the 2.8L kit."
    Piston MSRP: $3470.00
    Titanium Top Ring MSRP: $480.00
    GTRC Piston Price: $3049.00
    GTRC Top Ring Price: $409.00
    Connecting Rods:
    Eagle Specialty H-Beam Connecting Rods
    - RB26DETT Only, will need an RB26 crankshaft to use these.
    - Weight: 495g /each Journal Size: 1.889/ Length: 4.783/ Pin Size: 0.826
    P/N: CRS4783N3D
    MSRP: $600.00
    GTRC Price: $450.00
    Carrillo Connecting Rods (H, A, SA beam)
    - Made for RB25 & RB26. RB20 is special order: $100 more.
    - Stroker sizes available
    - Set balanced to + or – 1 gram, Fully Machined
    - Taper or Straight blade
    - Available with CARR or WMC fasteners
    - Laser Edged, 100% Magnaflux inspected
    - Made in USA
    Part numbers
    Super-A: DA-RB<SA-64783H
    H-Beam w/Carr bolts: DA-RB2>-64783S
    H-Beam w/WMC bolts: DA-RB2>-64783H
    A-Beam: DA-RB-1<A-64783H
    MSRP:
    Super-A: $1370.42
    H-Beam w/Carr bolts: $1908.08
    H-Beam w/WMC bolts: $1583.63
    A-Beam: $1304.42
    GTRC Pricing:
    Super-A: $1099.00
    H-Beam w/Carr bolts: $1529.00
    H-Beam w/WMC bolts: $1266.90
    A-Beam: $1049.00
    Engine Bearings:
    ACL Race Bearings
    - Price includes all Mains, Rods, and the Center Main.
    - Standard or Oversize available
    - RB30, RB26, RB25 & RB20 available.
    * Will update with MSRP and P/N's later.
    GTRC Price: $179.00
    Nismo Engine Bearings
    - 4 different conrod bearing sizes, 7 different main bearing sizes and 7 Center Main bearing sizes for optimum fitment!
    - Used on the VRH50A engine in the R391 competing in the 24 hours of Le Mans, the NISMO exclusive surface treatment dramatically increases durability. Can also be use with the RB25 series.
    - Seizing load limit: 20% up
    - Abrasion resistance: doubled
    - Anti-cavitation performance: up 60%
    Conrod MSRP: $36.00 per cylinder
    Main MSRP: $42.00 per cylinder
    Center Main MSRP: $51.50
    GTRC Prices:
    Conrod: $32.40 per cylinder
    Mains: $37.80 per cylinder
    Center Main: $46.35
    Power Enterprise F1 Black Metal Bearings
    - RB25 & RB26
    - Crystallized pyramid shape overlay.
    - The crystallized pyramids overlay of POWER F-1 bearing retains more oil on its much larger surface resulting in lower film pressure, lower bearing/journal temperature and help floats the crankshaft centered. It reduces crank shaft temperature by 20 degree C (68 F) lower than any other leading racing bearings.
    Conrod MSRP: $324.00 per set
    Main MSRP: $360.00 per set
    Center Main MSRP: $68.00
    GTRC Prices:
    Conrod: $291.00 per set
    Mains: $324.00 per set
    Center Main: $61
    Stroker Kits:
    Tomei RB2.8 Stroker Kit
    - Titanium Top Rings are optional
    - Cooling Channel Pistons are optional
    MSRP (non-cooling pistons): $5690.00
    GTRC Price: $5049.00
    HKS Step (2) 2.8 Stroker Kit
    MSRP: $9920.00
    GTRC Price: $8432.00
    Cometic Engine Gasket Set
    P/N: (RB26) PRO2017A & PRO2017B
    Top End: .051” MLS Head Gasket 87MM Bore, MLS Exhaust Manifold Gaskets, Turbo Outlet Gaskets, Throttle Body Gaskets, Intake Manifold Gasket, Idle Air Bypass Gasket, Intake Valve Stem Seals, Exhaust Valve Stem Seals, Cam Seals, Left Valve Cover Gasket, Right Valve Cover Gasket, Turbo flange Gaskets, Eye Bolt Copper Washers, Turbo Air Inlet Gaskets, Eye Bolt Copper Washers, Turbo Oil Inlet Gaskets, Large Fuel Rail O-Rings, Medium Fuel Rail O-Rings, Small Fuel Rail O-Rings, Crank Angle Sensor O-Ring, Engine Temp Sensor/Air Release, Large Eyebolt Washers, Vacuum Tube Chamber Gasket, Recirculation I-Cooler Gasket, Eyebolt Washers
    Bottom: Rear Main Seal, Front Crank Seal, Oil Filter Housing Gasket, Oil Pump Mounting Gasket, Oil Strainer Gasket
    MSRP: $345.90
    GTRC Price: $319.00
    OEM Nissan Gasket Kit
    - RB20, RB25 & RB26 available.
    GTRC Price: $199.00
    ARP Headstuds
    ARP2000 RB26DETT
    P/N: 202-4207
    MSRP: $498.00
    GTRC Price: $259.00
    ARP2000 RB20/RB25
    P/N: 202-4301
    MSRP: $239.00
    GTRC Price: $149.00
    ARP L19 Special Order RB26DETT
    MSRP: $1250.00
    GTRC price: $650.00
    Jul 2006
    Lethbridge AB
    5,269
    Top End parts
    - RB26DETT part numbers and pricing listed, please contact for RB20 or RB25
    - No GST on sale
    Ferrea Valvetrain Components
    Competition Plus Valves
    Part Numbers:
    Exhaust: F2131P
    Exhaust +1mm: F2132P
    Intake: F2133P
    Intake +1mm: F2134P
    MSRP:
    Exhaust: $42.55 each
    Intake: $30.45 each
    GTRC Price:
    Exhaust: $35.00 each
    Intake: $25.00 each
    Dual Valve Springs
    P/N: S10090
    MSRP: $25.25 each
    GTRC Price: $22.00 each
    * These require Titanium Retainer # E11057 & Spring Seat Locator # SL1047
    Titanium Retainers
    P/N: E11057
    MSRP: $17.87 each
    GTRC Price: $14.89 each
    * These require Dual Valve Springs # S10090 & Spring Seat Locator # SL1047
    Spring Seat Locator
    P/N: SL1047
    MSRP: $6.83 each
    GTRC Price: $5.45 each
    Stainless Steel Valve Locks
    P/N: K10072
    MSRP: $5.55 each
    GTRC Price: $4.44 each
    Supertech Valvetrain Components
    Black Nitrited Valves
    * oversize only
    Intake +1mm: NIVN-1032
    Exhaust +1mm: NIVN-1032/7
    MSRP
    Intake: $22.96
    Exhaust: $35.96
    GTRC Price
    Intake: $17.81
    Exhaust: $28.77
    Valve Springs:
    Single Valve Spring with Titanium Retainers
    P/N: SPR-M1007S/RB
    MSRP: $591.78
    GTRC Price: $473.42
    Dual Valve Spring with Titanium Retainers
    P/N: SPR-M1007D/RB
    MSRP: $657.53
    GTRC Price: $526.03
    Dual Valve Spring with Titanium Retainers/Seats
    P/N: SPR-M10015/RB
    MSRP: $735.00
    GTRC Price: $588.00
    Magnesium Bronze Valve Guides
    P/N
    Intake: GDE-NSR6-I
    Exhaust: GDE-NSR7-E
    MSRP: $7.71 each
    GTRC Price: $6.16 each
    Valve Seals
    P/N:
    Intake: VS-N6I
    Exhaust: VS-N7E
    MSRP:
    Intake: $0.65 each
    Exhaust: $0.96 each
    GTRC Price
    Intake: $0.52 each
    Exhaust: $0.77 each
    Tomei Powered
    Poncam
    - 260 or 252 Duration
    - 9.15 Lift
    * Type A
    Designed to best suit the stock & N1 turbos for optimum performance balance of low to mid range torque.
    The Exhaust cams duration was reduced to maintain best idling.
    * Type B
    By extending the duration timing compared to the Type A Poncams, both response and peak power was raised and these camshafts best compliment the mid to large size turbo charged applications.
    MSRP: $780.00
    GTRC Price: $663.00
    Procams
    - 252 to 290 Duration
    - 9.15 to 11.5 Lift
    MSRP: $390.00 each
    GTRC Price: $331.50 each
    Cam Gears
    Tomei
    MSRP: $180.00 each
    GTRC Price: $153.00 each
    GReddy
    MSRP: $180.00 each
    GTRC Price: $142.20 each
    Tomei Gasket Kit
    MSRP: $450.00
    GTRC Price: $382.50
    Tomei Solid Valve Lifters
    MSRP: $520.00
    GTRC Price: $442.00
    Tomei Timing Belt
    MSRP: $180.00
    GTRC Price: $153.00
    GReddy Timing Belt
    MSRP: $132.00
    GTRC price: $104.28
    * Please contact for Tensioner, Idler, Idler Spring Pulleys and other sensors/attachments for the engine.
    Regards,
    Braden @ JNS
    GTRCer ozalkl's Avatar
    Jan 2011
    Edmonton, AB
    52
    Hi Quote me for Timing Belt (OEM) and Tensioner, Idler, Idler Spring for R32 GTST Type M Automatic, with shipping to Edmonton AB
    1991 GTST Type M
    GTRCer BenC's Avatar
    Jun 2007
    Lethbridge, Alberta
    964
    PM sent!
    GTRCer evilgtr's Avatar
    Jun 2009
    Moose Jaw Saskatchewan
    837
    Hi Braden, sent you a pm regarding a crank damper. thanks
    Jul 2006
    Lethbridge AB
    5,269
    Hi Jeff,
    Got your PM, sending you a reply right away.
    Regards,
    Braden @ JNS
    Apr 2008
    Calgary
    90
    PM sent
    Jul 2006
    Lethbridge AB
    5,269
    Hi Justin,
    You have a PM back sir!
    Regards,
    Braden @ JNS
    GTRCer Collector1313's Avatar
    Dec 2010
    In the shop
    59
    Hey Braden
    im doing a full build on my head for extreme revin, I need to figure out total pricing for what I will need
    I will pm you and provide my email
    thanks
    always building
    Jun 2010
    Edmonton
    86
    Dol those tomei solid lifters colme for rb20det? and do they drop right in?
  1. Suspension Components
    By Braden @ JNS Imports in forum JNS Imports
    Last Post: 04-27-2011, 03:25 PM
  2. NEED GST-T suspension components
    By krispenev in forum Want to Buy
    Last Post: 06-05-2008, 05:21 PM
  3. Looking to buy suspension components...which ones?
    By Kirk in forum GT-R Discussion
    Last Post: 08-24-2007, 09:52 AM
  4. R33 Longblock with R32 components
    By Konkman in forum GT-R Tech
    Last Post: 10-31-2005, 06:37 PM
