Results 1 to 9 of 9
Thread: Fuel Components
    GTRCer Braden @ JNS Imports's Avatar
    Jul 2006
    Lethbridge AB
    5,269
    Fuel Components
    Hi guys,
    Here is fuel component pricing, please refer to this when purchasing from us. We can get other brands but we usually recommend these and get them the quickest. If you would like another brand let me know and I can price!
    - Please contact me for stock checks
    - Prices subject to change without notice
    - Shipping is extra unless otherwise stated.
    - No GST on sale
    - Canadian price is an example price, to show rough cost. Proper exchange must be done!
    *** Only Skyline applications listed, for other applications please message me.
    Payment types accepted: Visa, Mastercard, Debit Interac, Email Money Transfer, Paypal, Wire Transfer, and Certified Check.
    - customer must pay all fees associated with the transaction.
    Fuel Injectors:
    Injector Dynamics
    For those that don't know Injector Dynamics here is a bit of information on there product! Some of the best tuners in North America are using these injectors and swear by them! Many NHRA cars have switched to ID, and we have also used a couple sets in vehicles including Ben's RB26 which idles like stock without a tune. We simply will not sell you any other injector these days period!
    * Injector Dynamics was the first injector offered with full dynamic characterization providing tuners with the data they needed to do their job properly.
    * ID was the first injector to be offered in dead time matched sets.
    * ID was the first high impedance high flow injector available providing stock idle and drivability on engines as small as 325cc per cylinder.
    * ID was the first injector offered with the now famous "Top Hat Adapter" making it plug and play in nearly any application.
    * With a maximum pressure capability of 7 bar and excellent low pulsewidth extension, this is a versatile injector that will be at home in many different applications.
    * From high power high boost daily drivers, to NHRA Pro Stock Motorcycles and record setting turbo road race sedans, the ID1000 set the standard and marked the beginning of a new era in fuel injector performance.
    * Nominal Dynamic Flow Rate - 1000cc/min @ 3.0 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
    * Fuel Compatibility - Compatible With All Known Fuels
    Price below includes:
    - (6) Injectors
    - (6) Injector Clips
    - (6) Adapters
    - Flow Charts
    750cc: $675.00 for 6
    1000cc: $675.00 for 6
    1600cc: $1319.70 for 6
    2000cc: $1439.70 for 6
    ID1000's pictured:
    Fuel Rails:
    Powerhouse Racing Polished or Anodized Fuel Rail
    Powerhouse Racing has evolved around quality and perfection and with the new Skyline community we bring the High Flow Fuel Rail Kits that come in both Polished and Black Chrome. These rails are always in stock and have key features that leave other companies behind:
    * Injector bosses which replace the rubber orings to but a tight fit on the o-ring on the injector.
    * Black Chrome or Polished.
    * 14mm Domestic Style Injector Size or 11mm Denso Style Injector Size.
    * Mounting Brackets for either RB25DET or RB26DETT
    NOTE - All Fuel Rail Kits come with a full install kit, nuts, bolts, orings, fittings and mounting brackets to make this a breeze of an install!
    MSRP: $450.00 USD
    GTRC Price: $399.00
    Tomei Fuel Rail
    - includes rail, fittings, and mounting hardware.
    P/N: 253002
    MSRP: $370.00 USD
    GTRC Price: $315.00
    Fuel Pressure Regulator
    Fuel Lab Fuel Pressure Regulators
    Will be updated soon with parts, and pricing!
    Tomei Fuel Pressure Regulators
    - fuel pressure adjustment limit 200 - 600KPa (2 - 6kg/cm2) (Volume: 40L/h)
    - Diaphragm dia. ø36.5
    - Use temp. limit
    - 30°C - 120°C
    - Pressure transition slope 157 x 10KPa/L/H
    - shakeproof 250m/sec
    Type-A
    * Fits directly to OEM RB26/25 Fuel Rails
    P/N: 192019
    MSRP: $190.00 USD
    GTRC Price: $161.50
    Type-B
    * Remote mounted with use of ø8 rubber lines
    P/N: 192020
    MSRP: $190.00
    GTRC Price: $161.50
    Type-C
    * Remote mounted with use of -6AN Fittings
    P/N: 192021
    MSRP: $230.00
    GTRC Price: $195.50
    Fuel Pumps
    Fuel Labs Inline Fuel Pumps
    Tomei Direct Fit Fuel Pump R32/R33 GTR
    When upgrading your engine to get more power, just by upgrading the turbo and camshafts alone are not enough. Larger turbos and cams will require more fuel to feed the engine to match the increased air flow.
    P/N: (R32) 17042R585 & (R33) 17042R595
    MSRP: $530.00 USD
    GTRC Price: $450.50
    Walbro USA Fuel Pump & Wiring Kit
    MSRP: $172.00
    * price includes pump and wiring/sock kit
    GTRC Price: $120.00
    Bosch 044 Fuel Pump
    MSRP: $299.00 USD
    GTRC Price: $190.00
    Fuel Filters
    Fuel Lab Fuel Filters
    Powerhouse Racing Fuel Hat RB20/25
    MSRP: $250.00
    GTRC Price: $225.00
    Regards,
    Oct 2008
    Belleville
    256
    Really interested in at least 2 bosch 044 pumps. I just want to verify they are external. also wat are the internal and external connections
    thanks.
    Jul 2006
    Lethbridge AB
    5,269
    Hi sir,
    They can be ran both external and internally, we also sell the sock kits to fit on them.
    Threads are M18x1.5 inlet, M12x1.5 outlet
    Regards,
    Braden @ JNS
    GTRCer NerdJuice's Avatar
    May 2007
    Edmonton, AB.
    604
    Do the ID 1000s fit SARD fuel rails?
    1990 Nissan Skyline GTR Nismo Edition - Action Hotdog Go!
    1998 Subaru Legacy 2.5GT- Dirty Daily Driven
    Quote Originally Posted by gtrlux View Post
    Justifying needs reason, and reason is what you have to leave behind when you enter GTR ownership
    Jul 2006
    Lethbridge AB
    5,269
    Hi Steve,
    Yes sir the 11mm version is the ones you need. We have these in stock at our Canadian location ready to ship.
    Regards,
    Braden @ JNS
    Oct 2008
    Belleville
    256
    what is the availability of the 2 fuel pumps? also could i grab a price on -10AN in and out 10 micron 5" fuel filter. thanks
    Jul 2006
    Lethbridge AB
    5,269
    Hi sir,
    We currently have 1 left in stock, however they are easy to come by. I emailed then just now checking stock!
    Can price the Fuel Filter tomorrow, getting a new catalog from Fuel Lab as prices changed for 2011.
    Regards,
    Braden @ JNS
    GTRCer NismoS-tune's Avatar
    Jun 2008
    Alberta
    4,233
    Got any better fuel filters that fuel lab? -6AN is big enough for my 600whp
    If you can convince me, I might buy some ID injectors... PM me if you dare
    lol
    Jul 2006
    Lethbridge AB
    5,269
    What filter would you like? The Fuel Lab filters to 10 microns and come in 6AN. We can also get Earls (35 microns), Russell (10 or 35) and Aeromotive.
    And I will shoot you a email later tonight once I get information from Carbonetics for you
    Regards,
    Braden @ JNS
  1. Suspension Components
    By Braden @ JNS Imports in forum JNS Imports
    Last Post: 04-27-2011, 03:25 PM
  2. NEED GST-T suspension components
    By krispenev in forum Want to Buy
    Last Post: 06-05-2008, 05:21 PM
  3. Fs: Sard Fuel Components
    By ZENITANI_GTR in forum Parts for Sale
    Last Post: 04-22-2008, 10:52 AM
  4. Looking to buy suspension components...which ones?
    By Kirk in forum GT-R Discussion
    Last Post: 08-24-2007, 09:52 AM
  5. R33 Longblock with R32 components
    By Konkman in forum GT-R Tech
    Last Post: 10-31-2005, 06:37 PM
